APS install help please.
Old Aug 26, 2008 | 06:55 PM
Z06Samuel's Avatar
Z06Samuel
Default APS install help please.
Hello, I am installing the APS kit on an 02 Z06. I am on step 59 where it requires you to drill out the breather 1/4". On the back of my Left Valve cover I have a black plastic cap, and no breather. Is the breather on other years?
TIA,
Sam
Old Aug 27, 2008 | 02:56 PM
i2oyal i2ed's Avatar
i2oyal i2ed
BUMP for ya..
Old Aug 27, 2008 | 08:15 PM
AVB's Avatar
AVB
Is that for crankcase evac? If so, maybe it can just be taken from the passengers side.
Old Aug 28, 2008 | 12:59 AM
Z06Samuel's Avatar
Z06Samuel
Thanks Guys!
Rich was kind enough to look up the part, no dice on a breather. I am starting to think maybe there is a California smog difference?
Sam
Old Aug 28, 2008 | 01:23 AM
bullitt4110's Avatar
bullitt4110
LS2 valve covers have a nipple that needs to be drilled out, but snice you ahve the LS1/6 valvecovers you may be able to a fitting to push into the gromet. Just an idea.
Old Aug 28, 2008 | 03:45 AM
Z06Samuel's Avatar
Z06Samuel
Thanks man, I will try the LS 2 route, as the breathers/pvc valves @ pepboys don't look like they will cut it.
Sam
Old Sep 8, 2008 | 02:31 PM
hawkeyeintx's Avatar
hawkeyeintx
I am considering the APS TT kit for my 04 C5 LS1. What year and model is your vette? Are you doing the install? How easy is it? How much time has it taken you? Are you adding a booster fuel pump and new injectors?
Old Sep 8, 2008 | 03:17 PM
Z06Samuel's Avatar
Z06Samuel
It is a time consuming install, and my lift gave out on me! I am by no means a REAL mechanic, but with the help of the great folks on this forum (AVP, SPEEDY D) and one of my best friends it has been easy. I am going with a dual pump intank setup, I already bought 60lbs injectors. So far, I am giving myself a month date to get it running again. If you need any help answering questions, feel free to ask.
Sam 2002 Z06
Old Sep 8, 2008 | 03:37 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
FYI the LS1 PCV system has a port on the rear of the driver's side valve cover and the passenger side. For your LS6 the valve covers don't have breathers as your PCV vents from the valley cover under the intake manifold. The only port you'll have is a fresh air feed line that goes from your passenger valve cover to the throttle body.
I'm guessing the instructions are asusming LS1 valve covers?
Old Sep 8, 2008 | 04:55 PM
SpeedyD's Avatar
SpeedyD
Sam 2002 Z06
Sammy, no prob, any time I can help give me a call!
That goes for any one doing and APS, feel free to contact me for help.
Dan
To APS install help please.
