Upgrade clutch pack???
Old Aug 26, 2008 | 09:23 PM
1999vettrroo's Avatar
1999vettrroo
Default Upgrade clutch pack???
At what HP levle should you upgrade your clutch pack? I'm about to have hardened output shafts installed and wondered if I should go ahead and upgrade the clutch pack in the diff. I know there is a bunch of you gys that have changed yours.
I'm @ 500rwhp+ and 500rwtq+
Old Aug 26, 2008 | 11:38 PM
TYSON1997's Avatar
TYSON1997
I would change them. Buy the c6z clutch packs and springs they are the best bang for the buck period. It is a huge improvement over stock, and in my opinion superior to alot of the aftermarket cryoed oem clutch packs that you see shattered alot! Pm me and Ill tell you which ones not to buy, because I have had alot. C6Z's are a pucked design and made of carbon fiber, and the springs that are quite a bit stiffer than the c5 oem clutch packs, while they are cheaper than most aftermarket sets.
Old Aug 27, 2008 | 09:17 AM
vrybad's Avatar
vrybad
So the C6Z clutch packs will fit right in?
If so, I'll keep that in mind for the future.
Thanks for the info.
Old Aug 27, 2008 | 09:27 AM
1999vettrroo
Thanks for the info.. I sent you a pm.
To Upgrade clutch pack???
