Vortech pulley question???
Old Aug 27, 2008 | 11:01 AM
chargedc5's Avatar
chargedc5
Default Vortech pulley question???
I have a 2000 with LT's and S trim vortech which dynoed at 498rwhp corrected using a 3.6 pulley. My question is how much hp/tq should I gain going to a 3.0 pulley and a course how safe will it be? Or if i go with a 3.4 pulley will I see enough difference? Keep in mind that I do not have meth but will be adding it either way I go. Next question is how much power I would be adding with 3.0 pulley plus meth and 3.4 plus meth?
Thanks guys
Old Aug 28, 2008 | 03:47 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
It depends on how well and aggressively the car is tuned now as well as how it is tuned afterwards. I figure it should make about 620+rwhp on a nice meth tune with a 3.0 pulley. Go down to the 3.4 and I'll guess about 560.
Old Aug 28, 2008 | 04:39 PM
briann510's Avatar
briann510
I also have a 3.6 pulley but also with a restrictor plate added and made 525 rwhp. I never wanna use meth and wanted to keep a very conservative tune with stock bottom end and clutch so its just fine for me as is but could easily bump it up some if need be taking restrictor plate out.
If dropping pulley size make sure your tuner knows what the heck he is doing with timing and fuel trims....
Old Aug 28, 2008 | 06:20 PM
FreddyG's Avatar
FreddyG
Thanks guys
The above numbers sound about right!
I'm not sure where Georgetown, Indiana is, but make sure you use a good tuner if you do either. That'll make all of the difference in how long your motor lasts.
A couple of good ones are EPP (forum vendor) and GLM (Chad @ Green Light Motorsports). Jesse Bubb @ Wait4me Performance is also VERY good, but I think that he only does mail order tunes.
Good Luck!
Old Aug 28, 2008 | 07:12 PM
TRIZ's Avatar
TRIZ
Thanks guys
chargedc5,
When I changed from a 3.6 to 3.4" pulley I picked up 37rwhp
running a forged 346 and S-trim.
Right now I'm running a 3.0" pulley but haven't dyno'd it.
A rule of thumb is 20rwhp for every 1 psi increase in boost.
Another rule of thumb: Vortech says 1 to 1.5 psi increase in
boost for each drop in pulley size.
Check their website for pulley size increments.
After adding meth I just kept adding timing until knock
then backed off a little (meth hp is difficult to figure).
Old Aug 28, 2008 | 10:31 PM
chargedc5's Avatar
chargedc5
ttt
thanks
Old Aug 28, 2008 | 11:29 PM
FreddyG's Avatar
FreddyG
I forgot in my earlier post...... I run a 3.4" pulley with the restrictor plate along with an ECS meth kit and am around 500-525 rwhp, but haven't dynoed/tuned the boost VE table yet. This is through an A4 with a SY3500 converter too.
If I were to want to do what you want to, I'd put the meth on and bolt up the 3.0" pulley and see what she'll do! If it gets to be too much, then put a restrictor plate in and you'll be all set.
Good Luck!
Old Aug 30, 2008 | 02:34 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
I would not go lower than 3.2 pulley on a S trim without restrictor on stock short block unless the tune is perfect.
Old Aug 30, 2008 | 03:19 PM
dascorcha21's Avatar
dascorcha21
how much boost would a 3.0 and a 3.2 pulley make.
were is the s-trim the most efficient?
Old Aug 30, 2008 | 06:16 PM
FreddyG's Avatar
FreddyG
The person in the post right above yours is the man to talk to!
He's a been there, done that!
Old Aug 30, 2008 | 09:45 PM
c52k1vert's Avatar
c52k1vert
916/795 rwhp C5R 412 YSI
The S-Trim has a Max Impeller Rating of 50K RPM, Max Impeller Efficiency at 45K RPM resulting in 72% Adiabatic Efficiency. If the compressor starts generating excessive heat then you will be robbed you of boost. So if you are running a crank pulley size of 7.5", with a pulley size of 3.4 then you will hit Max Impeller RPM at Engine RPM of 6570 RPM and Max Impeller Efficiency @ Engine RPM of 5913. By dropping to a 3.0 pulley size you will hit Max Impeller RPM at Engine RPM of 5797 RPM and will hit Max Impeller Efficiency @ Engine RPM of 5217. Most look for their power at peak torque curve and not peek HP curve and try to pulley for that range and normally do not rev the engine for any extended period of time at those RPM's.
This information is important because as you heat soak the air you are injecting you will loose its effectiveness. I personally favor Alky to cool things down at high boost levels and removing IC's which can drop as much as 1 to 3 PSI.
Old Aug 30, 2008 | 11:23 PM
FreddyG's Avatar
FreddyG
Great information!
Thanks for sharing it!
Old Aug 31, 2008 | 12:50 AM
FactoryRaceCar
Just remember, you only overspin the blower for a second or so in each gear even if that. Life begins with overspinning
Old Sep 1, 2008 | 05:20 PM
chargedc5's Avatar
chargedc5
So you guys are saying that the most I should drop to still be efficient is 3.2 with alky.
Old Sep 1, 2008 | 10:30 PM
FreddyG's Avatar
FreddyG
This is a good post and what I took out of it is that you can keep max efficiency if you don't spin the motor to 6500-6800 rpms while using either a 3.2" or 3.0" pulley. If you spun your motor to 6000 rpms with the 3.0", then you're just a little over the max rpm or max efficiency of the impeller. Granted with a perfect tune, you could spin it higher, but then you're taking your chances.
Wouldn't the blower impeller rpms change if you put an 8" 8 rib on?
Good Luck!
To Vortech pulley question???
