I have a drag pack on the way and want to setup the car for some all out passes. I'd like to remove the plate and adjust the tune with some race gas. I'd like to get deep into the tens.
How much boost will I pick up by removing the plate from my kit? Right now it makes 10lbs. max.
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Well... that exact combo in Asmokegars ZO6 netted a 9.80 @ 142. with our blower cam. You will see aproximately 12-13lbs. Make sure you have a spot on tune and 100% race fuel. (unleaded)
how much hp and tq does the setup put out? (no restrictor, meth, race gas, and 12-13lbs)
Excellent. I have your cam as well, so only difference is the auto tranny I guess.
Charlie will be tuning the car. Is 100 octane unleaded sufficient? They sell it at the pump by work. They also have 109 unleaded in the 5 gallon jugs but it's $14 a gallon
From: ECS : WTF did you break now and HTF did you break it this time
From: Still the Fastest (still running) Stock Bottom End Blown LS1/ 2010 ECS CC 10.50 CHAMP Hamilton, NJ
When I removed my restrictor, I saw 14 lbs. It netted me a 9.82@139, and a 9.84@137, but I only spun the motor to 6500. asmokegars was a tiny bit higher. The pulley I use is the one that came with the kit and I have the cam and meth also. I wasnt running straight race gas. I had about 1/3 of a tank of 93+torco and then added about 3 gallons of 100. Make sure the tune is dead on...
I have since put the restrictor back in, and slowed the car down...
