Ecs sc600 setup
Old Sep 10, 2008 | 01:39 PM
QUIKSILVERZ's Avatar
QUIKSILVERZ
Default Ecs sc600 setup
i have a bone stock 2002 Z06 that i am thinking about adding a s/c to. I really like the ECS systems so i am leaning towards their sc600 kit. I also will be adding a set of long tube headers/off road x-pipe. The car is a street car above all else. But i will attend a couple open track events and a few trips to the 1/4 a year. Anyone running a similar combo? Any other parts or options you would suggest? Any track or dyno numbers? Thanks
Old Sep 10, 2008 | 03:08 PM
samsonxd's Avatar
samsonxd
My car on the Mustang Dyno made 531 RWHP and 476lbs of torque on 8#'s no meth. I have Afr heads, kooks long tubes and X pipe, B&B exhuast no cats, and Billet nitrous cam 236/238/112 (switching that out)
Old Sep 10, 2008 | 05:09 PM
FRC Joe's Avatar
FRC Joe
You'll be needing a high performance clutch right away. Also, for open tracking, you will likely want to add a thicker cored radiator.
Old Sep 10, 2008 | 07:42 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
Other than that, the ECS kit is a very complete kit.
You wont go wrong with their setup. If I ever go to a centrifugal, I wont make the same mistake as the last time. I'll go with the ECS...
Old Sep 10, 2008 | 08:59 PM
Dave concrete's Avatar
Dave concrete
04Z with a ECS installed Novi,meth kit ,AR headers hi-flow cats into stock Ti's Tex clutch, DTE brace,MGW shifter,Lingenfelter shafts and we made 581rwhp and 488rwtq at about 7psi. You can't go wrong and very streetable and reliable given you don't beat the **** out of it.
Old Sep 10, 2008 | 09:07 PM
BLOWNZO6's Avatar
BLOWNZO6
Premium Supporting Vendor
You will not be sorry about going this direction. On your stock Z you can get an easy 550-600 to the wheels. Will be a nice setup.
I am an ECS dealer and in Knoxville TN if I can help you out!!
__________________
EAST COAST SUPERCHARGING SALES AND TECH SUPPORT
WWW.EASTCOASTSUPERCHARGING.COM
Old Sep 10, 2008 | 10:04 PM
NemesisC5's Avatar
NemesisC5
For roadcoursing a Dewitts radiator along with an external oil cooler will be a must
Old Sep 11, 2008 | 04:01 AM
QUIKSILVERZ
thanks guys for the help. sounds like a lot of happy customers.
Old Sep 11, 2008 | 09:31 AM
DOUG @ ECS's Avatar
DOUG @ ECS
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
If you need an installer near you, Nick is the man!
Old Sep 11, 2008 | 01:13 PM
QUIKSILVERZ
should i go with a 1 3/4" long tube or 1 7/8" kit? i am sure i would want to turn the boost up and or add a 402ci down the road.
Old Sep 11, 2008 | 03:23 PM
CraZee ZO6's Avatar
CraZee ZO6
with your goals.. 1 7/8
ECS makes the best complete S/C kit out
Old Sep 11, 2008 | 04:11 PM
Chris@East Coast Supercharging's Avatar
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
With your future goals I would just start off with the 1 7/8 set
Old Sep 11, 2008 | 04:28 PM
QUIKSILVERZ
thanks again ECS and everyone else. Look forward to doing buisness with you.
To Ecs sc600 setup
