problem
Old Sep 18, 2008 | 06:26 PM
MalachiZ06's Avatar
MalachiZ06
Default problem
car isnt feeling as fast as usual dont think its just me being bored with it, doesnt seem im building boost like i use to also, seems to just cut off at 4 instead of 6.5 just seems laggy
Old Sep 18, 2008 | 07:13 PM
slowtealz28's Avatar
slowtealz28
Check for vacuum leaks?
Old Sep 18, 2008 | 07:14 PM
slowtealz28
and/or exhaust leaks
Old Sep 18, 2008 | 07:34 PM
MalachiZ06's Avatar
MalachiZ06
what do u guys use to check for both, also could the plugs and wires be a problem also if they needed to be changed think im do
Old Sep 18, 2008 | 09:23 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Do you have a boost gauge? Boost leak?
Old Sep 18, 2008 | 09:40 PM
MalachiZ06's Avatar
MalachiZ06
yes i have a boost gauge thats why im saying its only building 4psi, should be around 6.5 boost leak makes sense also exhaust leak could be a problem too ugh
Old Sep 18, 2008 | 10:04 PM
JET LEE's Avatar
JET LEE
Belt slipping maybe?
Old Sep 19, 2008 | 12:03 AM
MalachiZ06's Avatar
MalachiZ06
ugh i def hope not that one
Old Sep 19, 2008 | 08:11 AM
BLOWNBLUEZ06
When I first built my engine, I kept blowing the hose off the volute because there is no lip on the end. I was able to make 5psi boost with the output hose hanging off by 1/2". It was noisy when I was driving. If a good visual inspection doesn't reveal your problem, you can pressurize the entire system. Put a disc or cap in the system to block the throttle body end of your plumbing and cap off the other end with a fitting in the cap and put pressure across the plumbing using a compressor with the regulator turned down to help reveal your trouble. Your BOV could be stuck open, loose plumbing, torn hose, hole in intercooler. Give it a thorough inspection!
Old Sep 19, 2008 | 08:50 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I had my airbridge seperate on me and I thought something had gone terribly wrong
So check all the connections on the B@@ST side of the Supercharger
Thanks,Matt
Old Sep 19, 2008 | 10:03 AM
Zo3o6's Avatar
Zo3o6
Are you running cats?
Old Sep 19, 2008 | 10:40 AM
MalachiZ06's Avatar
MalachiZ06
no cats, have lg long tubes, there might be a hole in them its happened before since the car is so low, ive scarped them, ill check the vacuum lines
To problem
