Are these numbers right?
Old Sep 19, 2008 | 05:16 PM
03blackZ06's Avatar
03blackZ06
Default Are these numbers right?
03 z06 with
ssac headers + xpipe no cats
B&B prt exhaust
228/232 114 cam .589 .598
prc dual gold springs
D1SC procharger kit with A&A new bracket and ecs idler
Richard racing 4" ultragrip pulley
60lb injectors
msd boost a pump
619.1rwhp 589.1rwtq SAE corrected
644 rwhp standard uncorrected
on new dyno jet
with ccw 19x11 out back
Old Sep 19, 2008 | 05:49 PM
leojnknsC5's Avatar
leojnknsC5
How much boost do you get with the 4"?
Old Sep 19, 2008 | 06:08 PM
03blackZ06's Avatar
03blackZ06
Im seeing 6lbs
Old Sep 19, 2008 | 06:25 PM
whitebullet7's Avatar
whitebullet7
I have the same cam p1sc1 7psi 615/520
glennd's Avatar
glennd
Originally Posted by 03blackZ06
Im seeing 6lbs
I am sure you are running alot more than 6 psi with a 4" pulley when I was running a 3.85" on my 346" I was making 15.5 lbs @ 6600 rpm and 805 corrected 830 uncorrected rwhp'
My 416" with a 3.85" on a D1SC is at 14lbs and this is still using a stock diameter balancer.
Old Sep 19, 2008 | 09:35 PM
leojnknsC5's Avatar
leojnknsC5
Im seeing 6lbs
You didnt state it, so I'm assuming you've got stock heads. For that pressure, I'd say your in the ballpark.
Old Sep 19, 2008 | 09:38 PM
03blackZ06's Avatar
03blackZ06
What does your set up consist of?
Old Sep 20, 2008 | 01:38 PM
whitebullet7
01 stock ls6 motor,ls6 intake,kook 1 7/8 longtube header system no cat,stock ti,ram twin disc clutch,ecs new bracket(thanks Chris at ecs),p1sc-1,ati twin intercooler,tail bov,sd tune by Nick at Newtech(one of the best tuner around bay area),228/232 575/595 114 lsa ,60lbs injector,racetronic fuel pump and harness,meth,my new # is 655/565 @10 psi and 17* timing
To Are these numbers right?
