Procharger questions
Old Sep 22, 2008 | 12:33 AM
N4cer's Avatar
N4cer
Default Procharger questions
Okay in a few days I'll be installing a (used) P1 Procharger on my 2001 C5. I have a few initial questions.
1 - restrictors. Everyone says they are just a washer. Where can I find info on this so I know what washer to use with what pulley? I have a specific goal of an initial 450rwhp for specific reasons, and the rwhp will be incrementally increased as different goals are attained.
2 - Radiator drop. Where do I find info on this? The air intake goes directly over the radiator, so I need to drop mine (preferably vertically).
I'm sure I'll be asking more questions soon enough!
Old Sep 22, 2008 | 12:42 AM
BacktheBlu's Avatar
BacktheBlu
CF Senior Enthusiast
I just finished installing a P1SC on my 98 Vert.......I upgraded the stage one kit to a stage 2 kit available from Procharger. The kit has the new radiator cradle, intercooler tubing from the outlet Y, horn relocation kit, new intake, red hose mod kit etc..... The new kit should be good for 2 PSI over the old style system.
Definitely worth the $600.00.
Old Sep 26, 2008 | 12:33 AM
speedygc5's Avatar
speedygc5
I HAVE THE OLDER KIT AND
Old Sep 26, 2008 | 02:23 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Might want to try A&A's websit as they have PDF of there system install.
The use some spacers and longer bolts to drop the lower radiator support. There are some nice pictures of the install in the down loadable pdf.
http://www.aacorvette.com/pdf/aa_c5_instructions.pdf
Old Sep 26, 2008 | 09:12 AM
lionelc5's Avatar
lionelc5
Get the new bracket while they are still cheap. If you are going to get anything, pay the $500.00 and get the new brackets and tesioner from A&A.
Old Sep 26, 2008 | 01:33 PM
N4cer's Avatar
N4cer
I've got the A&A belt bracket in my setup. Just need to know what to do about the radiator.
Old Sep 26, 2008 | 02:15 PM
lionelc5's Avatar
lionelc5
I used the procharger cradle as the other guy stated above also. But what I was asking you if you have the NEW procharger bracket or the old style? http://forums.corvetteforum.com/show....php?t=2106141 (link to new A&A bracket)
You can just cut your existing radiator cradle and move the mounts and reweld them yourself if you dont wana pay for the procharger one.
Lionel C
Old Sep 26, 2008 | 02:54 PM
Arun@ChampionMotors's Avatar
0Arun@ChampionMotors
Former Vendor
You won't need a restictor with a P1-just put on 4.25 pulley and you'll meet your goals.
Old Sep 26, 2008 | 08:10 PM
FRCBobby's Avatar
0FRCBobby
Former Vendor
I still have teh instructions that came with my A&A kit if you need them. Also have a restrictor laying here you can take and copy.
Old Sep 26, 2008 | 09:27 PM
N4cer's Avatar
N4cer
Thank ya brother. I will certainly look at that restrictor and make a few since I'll end up going to a smaller pulley and restrictor.
I also downloaded a copy of the A&A setup, but it has the single FMIC instead of the crappy twins that I have. I might just order an eBay FMIC and do it myself instead of these crappy little twins.
Oh and the A&A instructions show the radiator cradle being dropped with spacers (not cut and rewelded). Is that a good or bad idea?
Old Sep 27, 2008 | 01:38 AM
OO7's Avatar
OO7
i dont no about alot of people buti believe in doing it right so you want have any problems.we have done about 100 C5 procharger installs,so lets see if i can help.i dont no how much you have in your sc but i have alot of upgrades for them,pulleys,brackets,crank pin kits,drain line kits,the extra large air to air intercoolers,what ever you need,let me no,thanks mike
Old Sep 27, 2008 | 01:41 AM
OO7's Avatar
OO7
oh yea,we also have the new cradle which re-aligns the radiator and air cond. condensor which alows alot better cooling than anyone elses systems out there.
is your car an auto or 6sp?
Old Sep 27, 2008 | 02:02 AM
N4cer's Avatar
N4cer
M6.
No cobbling here. My tuner's shop has done enough to help me just fine. I just prefer to do as much work as possible myself. I find it stupid to pay $550 for a cradle relocator when I can do it for the price of a cutoff wheel if I'm understanding correctly.
Old Sep 27, 2008 | 02:15 AM
waddisme's Avatar
waddisme
Hey man -
I just sent you a pm which has about everything said above in it. If you want, the brackets I used to lay my rad down are exposed now. I think they are just bolted in cradle. I can send you a drawing of them and you can make your own if you can't get them from Andy. Let me know if you want measurements and pics.
Old Sep 27, 2008 | 04:03 PM
OO7's Avatar
OO7
sorry,just trying to help
the new cradle is 399
it not only drops it alittle but it lays it back towards the motor for alot better cooling
To Procharger questions
