Guess how much HP
Old Sep 22, 2008 | 01:18 AM
jmoody66's Avatar
jmoody66
Default Guess how much HP
So heres the scoop. I have an 02 Z06 running 7 lbs boost through the STS setup, Twin GT32 turbos, 60 lb motrons, 2 bar map, racetronics upgrade. I just delivered the car and am having this done through Pavlock Performance over in Tomball Texas:
Comp grind of your choice with Double springs, Titanium retainers, new valve seals, Chrome-Moly pushrods, NGK TR-55 plugs, All new GM gaskets for the cam install, Professionally Dyno Tuned for only
1700.00!!
Package 2:
Everything Mentioned above as well as stage 2.5 heads flowing in the 310-315 CFM range with new GM head gaskets, NEW LS7 lifters and NEW lifter trays, GM head bolts and new water cross-over seals, and all front gaskets included in package 1, PB underdrive with belts, all installed and dyno tuned for only
3550.00!!
On top of this I am upping the boost to 10 lbs and having a Fidanza twin disc clutch put in as well.
I am relying on Pavlocks experience to choose a cam that best suits my application so I do not know the cam specs.
Whats your best guess at what I will put down...without going over. Remember you get a bonus prize of 1 tootsie roll for the most accurate guess....LOL
Old Sep 22, 2008 | 03:46 PM
jmoody66's Avatar
jmoody66
Default ??
1700.00!!
Package 2:
3550.00!!
You mean to tell me out of all these edumucated folks out thar not one of ya has even one guess? cmon guys
Old Sep 22, 2008 | 07:03 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Anything more than 550RWHP and you better start planning for a forged bottom end.
Hopefully your tranny and rear can take the extra power for awhile.
Old Sep 22, 2008 | 07:37 PM
CraZee ZO6's Avatar
CraZee ZO6
Yea I would leave it alone (heads cam) right now until you do the bottom end (pistons rods). Do that all together you will save money.
STS 7lbs and a stock zo6 should be 550rwhp... as is. With those new mods and 10lbs you will be wasy 650rwhp maybe more and not safe. ON THE EDGE. Might last some. I dont think stock pistons and rods would like that. I wouldnt risk it.
To Guess how much HP
