Low numbers?
Old Oct 11, 2008 | 12:18 AM
EVLZ06's Avatar
EVLZ06
Default Low numbers?
Ok finally got the car tuned today, and while the numbers were still stout..... I figured I would make a little more. 01 C5Z, stock longblock, A&A D1SC, meth, Kooks LT, OR X, 60# injectors, and boost a pump, 3.90 gears. It made 540/500@ 10psi. Its not a dyno queen by any means, just thought it was a little low.
Old Oct 11, 2008 | 12:55 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Well, the nicest part about this story is that you can always up the boost, but at this juncture, you will gain a bunch from a tasty cam in that car.
Call Andy at A&A and he'll give you a great cam based on your performance/driveability preferences.
Old Oct 11, 2008 | 12:56 AM
BLOWNBLUEZ06
Another thing is that gears lower dyno #'s. They decrease the load which decreases the HP reading. Not speculation.....fact!
Old Oct 11, 2008 | 01:08 AM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
If you want bigger numbers, switch back to 3.42 and add a blower friendly cam and use meth for fuel. You will be close to 700rwp with these.
Old Oct 11, 2008 | 01:27 AM
Shinobi'sZ's Avatar
Shinobi'sZ
My hp numbers from the very first A&A kit are listed in my sig. Click on link.
Same setup as yours stock long block at the time...no meth.
To Low numbers?
