Fuel problem
Old Oct 16, 2008 | 11:59 AM
run and gun's Avatar
run and gun
Default Fuel problem
I am having a issue with what seems like vapor lock, but not sure. After runing car for a while and sutting car down and starting car back up it seens to be not getting enougth fuel for the frist minute but clears right up. Only happens when hot so could be heat related. The car has racetronic fuel system with bap and 10 lbs boost.
Old Oct 16, 2008 | 02:41 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Try bumping the key for a microsecond and then starting the car. If it starts right up then you probably just have fuel pressure bleeding off when the car isn't running. I have the same issue and solve it by bumping the starter like I'm telling you to try.
