Need help with decision!
Old Oct 16, 2008 | 06:45 PM
black 99's Avatar
black 99
Default Need help with decision!
It is time yet again for me to ask for the corvette forum FI section whic is of course the best section for their advice. I have just purchased a 6.0 LS2 block, just the block. I will have it here in a couple days. I am torn between doing a 370 set up for my Top Mount Twin turbo set up. Which has been atop my stock bottom end thus far with very good results which you can see on my signature. Or a stroker motor set up. I know I am on borrowed time and hate having my heart clentch every time I step into the throttle and boost up waiting for it to go pop. I know what the next question is what do I want to accomplish, Well I want good mid range torque for those occasional highway pulls. I would also like to be able to put up some respectable numbers at the drag strip also. So I am going to be spraying about 100 shot, and I want to be able to run about 15 to 18 psi. So let me know what everyone thinks especially like info from fellow turbo guys. Thanks in advance for all your help. Long live boost. Jason
Old Oct 16, 2008 | 07:03 PM
undertaker's Avatar
undertaker
From: ECS : WTF did you break now and HTF did you break it this time
the torque from the stroker might cause you more traction headaches than its worth, I'd just put got pistons, rods and fasteners and stick with a stock crank if it were me. You'll make more than you can use on boost alone.....and you have the juice available for instant on torque...
Old Oct 16, 2008 | 07:54 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Well, you know what some say........You can always turn it down, but you can't always turn it up. You can make more power on less boost and spool the turbos more quickly with a larger displacement too. In other words, it might be easier on the engine with the extra displacement because you will be able to achieve the #'s on less boost. If your budget can take it, do it!
Old Oct 16, 2008 | 08:12 PM
NemesisC5's Avatar
NemesisC5
Dude, go stock cubes LS2...it wouldn't matter if you build a 500cid motor I know you are going to want 20psi Remember too, now you will have to further upgrade your fuel system to feed the beast
As is most always the case in the C5 FI section..."More Is Never Enough"
Old Oct 16, 2008 | 09:49 PM
Brian@FI Performance's Avatar
0Brian@FI Performance
Former Vendor
From: FI Performance : Norwalk Connecticut www.FIPERFORMANCE.com
What boost controller are you running? Turbo's? W.Gates?
Old Oct 16, 2008 | 10:05 PM
1%r's Avatar
1%r
St. Jude 15 Year Donor
St. Jude Donor '03 through '17
Turbos like displacement over stroke. Your going to have your hands full on the bottom if you go with a stroker.
I know!
Old Oct 16, 2008 | 10:11 PM
BLOWNBLUEZ06
I know!
So you're saying that the stroker motor will be too much for the turbos and is absolutely not necessary to achieve as much power as the turbos will yield or the car will ever be able to handle, so his extra stroker money would be better spent elsewhere? I know you have much experience in this arena and should be listened to. I consider Jason a friend and am therefore asking for clarification on his behalf.
Old Oct 16, 2008 | 10:17 PM
NemesisC5's Avatar
NemesisC5
Originally Posted by BLOWNBLUEZ06
....I consider Jason a friend.......
...Great Guy that loves his Corvette
Old Oct 16, 2008 | 10:23 PM
1%r's Avatar
1%r
I used to have a partnership in an import shop.....
Should have learned from all the turbo cars we did. When I did the Vette I elected to go with a 382 stroker. The car on the bottom end with the snails is out of control.
Save yourself the money on the crank and go with displacement or put it elsewhere. That is unless you want to go sideways on the bottom and not be able to hook up.
JMHO
Old Oct 16, 2008 | 10:56 PM
black 99's Avatar
black 99
Default Stroker
Hello Everyone,
Thanks Brett and Scotty guys are awesome. Two of the best friends a fellow modder addict could have. Thanks everyone for all the feedback. You are great help and this forum hasn't let me down yet. I want to put out a killer deal I just stumbled upon while looking for a clutch to go with my build. If you would like to know where you can get a MCCLEOD twin clutch for 899.99 with master cylinder PM me and ill hook you up with the link. Thanks again everyone Jason
Old Oct 16, 2008 | 11:58 PM
BLOWNBLUEZ06
Mcleod twin for 899.00? That's a steal!
Jason:" After I do this next thing, I'm done "
Uhh.....yeah right.
Congratulations! You're an addict! To top it all off, there's no medication offered for this! See ya in 5 years when you get your new top fuel dragster!!
Old Oct 17, 2008 | 06:30 PM
black 99's Avatar
black 99
Yeah I know I said that I was going to stick with what I have for awhile and just enjoy it, BUT after feeling 20lbs of boost those couple times I have to say 10 to 11 just isnt the same. Even my wife said it we were going down the interstate and I needed to get around a tractor in trailer decided to get around it quick. kick in my whapping 10psi and my wife looks at me and say yeah it is fast but it just doesn't feel the same. So call me hooked. I am a speed freak and moddaholic. And thanks to bambi running into me expensive bosy shop estimates and this forum I have alittle extra cash to make me forged motor happen. So at least 18psi here I come!!!!! By the way I didnt purchase the other motor. I ended up going on LS1 tech and Bought complete short block with rotating assembly for less and the guy lived about a hour from me. I am going to pick it up SUN. Then off to the machine shop it goes. Thanks again everyone. Jason
To Need help with decision!
