Compression question
Old Oct 22, 2008 | 12:10 AM
EVLZ06's Avatar
EVLZ06
Default Compression question
I am underway of installing a new 347 longblock that I bought off a forum member. I have an A&A D1SC and looking to make in the 700+rwhp on pump gas. My question is 10.1:1 compression going to limit me on reaching my goal? I have some ported/polished 317 heads with 72cc chambers that should lower the compression to 9.3:1, should I swap the AFR heads for the 317s?
Here is the build sheet.
General Description - 347 Aluminum LS1 Long Block
Short / Long Block - Long Block
Block Type - 5.7L Aluminum Gen III
Displacement (CI) - 347
Bore - 3.905"
Stroke - 3.662"
Application - Forced Induction
Desired Compression Ratio - 10.1:1
Core Provided? - No
Crank - OEM - Magnaflux and Balanced
Rods - Scat H Beam 6.100" x 0.927"
Pistons - Diamond with -2cc Valve Reliefs
Rings - Diamond
Cam Bearings - Durabond
Rod Bearings - FM
Main Bearings - FM
Main Studs - ARP
Main Caps - OEM
Rod Bolts - ARP
Heads - AFR 205cc
Head Fasteners - ARP studs
Head Gaskets - GM MLS
Camshaft - MTI "R1" hydraulic 232/236 115 LSA
Timing Chain - Rollmaster Dual
Oil Pump - None
Lifters - Comp Cams 850-16
Pushrods - Chrome-moly
Rocker Arms - None
Old Oct 22, 2008 | 06:00 AM
EPP's Avatar
0EPP
Former Vendor
No, I don't see it being a problem. Add a methanol injection kit to it and you can even put some timing in there. Bob
Old Oct 22, 2008 | 08:02 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
I wouldn't trade AFR's for 317's
Old Oct 22, 2008 | 09:04 AM
NemesisC5's Avatar
NemesisC5
Been running the AFR's on my stock bottom setup and the only problem I have is wheelspin
Old Oct 22, 2008 | 10:03 AM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
You shouldn't have any problem....maybe get a better set of Heads and defently add Methanol! !
Old Oct 22, 2008 | 10:11 AM
EVLZ06's Avatar
EVLZ06
Better set than the AFR's? Forgot to mention up top I have a methanol kit.
Old Oct 22, 2008 | 10:15 AM
EVLZ06's Avatar
EVLZ06
I'm just worried that with 10:1 compression its going to hold me back from running bigger boost safely!
Old Oct 22, 2008 | 10:19 AM
BLOWNBLUEZ06
My compression is 9.5:1 and I will be going to the dyno to get some new #'s this weekend hopefully, but I'm expecting over 900. With 1/2 point higher compression and a few less cubes, you still should easily be able to reach your goal and safely I might add.
Old Oct 22, 2008 | 11:16 AM
EVLZ06's Avatar
EVLZ06
I know there are more variables but how much boost could I safely run on pump gas?
Old Oct 22, 2008 | 03:00 PM
NemesisC5's Avatar
NemesisC5
The AFR's will generate higher power numbers and provide more torque throught the curve....10.1:1 is not high compression for boost by todays standards. If given a choice of 500rwhp with 9psi at 9.5:i CR OR 500rwhp with 7psi at 10.1:1 CR I would pick the lower boost version EVERY TIME Better throttle response and less chance of belt issues
Old Oct 22, 2008 | 03:06 PM
95vettski's Avatar
95vettski
Very well said The more efficient your combo is the less boost required to hit your goal.
Old Oct 22, 2008 | 03:53 PM
NemesisC5's Avatar
NemesisC5
Thank you sir You touched on a key word, "efficient". Generally speaking, the higher CR's make the most of the combustion stroke yielding more power & fuel economy...although I know that nobody in the FI section is interested in MPG
Old Oct 22, 2008 | 04:10 PM
EVLZ06's Avatar
EVLZ06
Thanks guys for all of the great responses I'm going to stick with the AFR's and let her rip!!
To Compression question
