anyone in here with lpe launch controller need help please
im wiring it up to clutch switch exactly as it say w/ relay but car wont start i have to tie the two wires i cut from the clutch switch together to get it to start, i thought with the relay in place, i will still have to push the clutch in to start, or is that no longer used? anyone please
When I hooked mine up,I found that the power feed,key on to the relay was NOT powered while cranking.In other words,if the wire you are using is NOT hot in the run/crank position both,it will not work.Pissed me off cause I wired it up at midnight,then tried to have my wife drive the car to work the next day,after I took her cruiser ! She was not happy climbing under the dash and twisting the two clutch switch wires together to start the car ! Let me know if you are still having trouble,it WILL work as shown in the diagram,LPE did a great job and provides great customer service should you have an issue.
Well my boy had to be to school and I had her car.At least she followed directions and got it running herself,gotta love her ! Hey,she even ran it at the track,she likes the launch control,it allows you to focus on the lights !
Great.I've got one on my C5 but havn't had time to use it yet.I'm preying for one more nice weekend.dosn't look good up here in the north
