Dual nozzle meth?
Old Nov 7, 2008 | 04:42 PM
95vettski's Avatar
95vettski
Default Dual nozzle meth?
When would you consider adding a second nozzle to spray more meth? Is it dependent on boost or power level? I currently have a single nozzle and looking to add a second if necessary.
Old Nov 7, 2008 | 06:10 PM
clif's Avatar
clif
St. Jude Donor '09-'10
I am installing a dual nozzle on my car. Why? Just becasue the person I bought the throttle body from had a custom ring with dual ports that he gave me with the TB!
Old Nov 7, 2008 | 06:40 PM
BLOWNZO6's Avatar
BLOWNZO6
Premium Supporting Vendor
I generally decide single or dual nozzle based on the application.
For stock bottom end car with 5-8 psi of boost, I use a single nozzle.
For anything forged where there is a potential to lean on it or running 12+ psi I always use a dual nozzle setup.
Hope that helps.
__________________
EAST COAST SUPERCHARGING SALES AND TECH SUPPORT
WWW.EASTCOASTSUPERCHARGING.COM
Old Nov 7, 2008 | 07:18 PM
Arun@ChampionMotors's Avatar
0Arun@ChampionMotors
Former Vendor
After 640 rwhp, dual nozzle all the way
Old Nov 7, 2008 | 11:09 PM
FunCool's Avatar
FunCool
10lbs and higher, single nozzle on a ls6 does not cut it, but a motor with 9 to 1 compression 12lbs would be o.k.
Old Nov 8, 2008 | 10:00 AM
95vettski's Avatar
95vettski
Okay, I'm shooting for more than 640 rwhp
Old Nov 8, 2008 | 11:04 AM
Former Vendor
Single nozzle:
10.25 CR-stock short, 12psi
Single nozzle:
LS6 stock short, 222/228 cam, 12 psi, 10.4@137
Only way to tell for sure-is to log a pull from start to finish@the track-not just on the dyno.
If the IAT temp is lower than the beginning of the pull then have enough alky. From our testing with centri's 640 was the limit a single nozzle.
Old Nov 8, 2008 | 11:27 AM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
I bought my kit with a dual nozzle
To Dual nozzle meth?
