Help!! with this combo !!!
Old Nov 11, 2008 | 09:28 PM
jparr's Avatar
jparr
CI 7-8-9-10 Veteran
St. Jude Donor '08
Default Help!! with this combo !!!
I been looking at a ls1 370 CID block for my car ...
http://www.texas-speed.com/shop/item...d=683&catid=83
what could I see (hp/rwhp) from this short block along with my P1-SC ?
Id probably use a EG havoc cam along with sum 317 heads !!
thanks jay
Old Nov 12, 2008 | 12:05 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
thanks jay
Why use an iron block ? You're not going for huge numbers.
Also why such a big cam ? You'll be bleeding off boost.
You could also do with deeper dish pistons to lower compression ratio and then use some LS6 Heads with upgraded valve springs.
How much boost did you plan to run ? Depending on the amount of boost, you'll need bigger injectors and fuel system upgrades.
