What nitrous kits are the best for a bone stock 2003 ZO6? I don't drive my car very often, but when I do I'm looking for the most explosive kit I can get. Suggestions welcome. Thank you!
Have you decided on wet or dry yet? I have nice plate kits that cover which ever style you like? Some good Vette specific info on my site that you may be able to glean some insight from. It's no secret that i like dry myself and have done it many way on the Vettes, from single nozzle to Direct Port. Are you planning to drag race? I currenlty have many hundreds of ¼ mile passes on my Z06 and they will hold up fine. These cars are absolute beasts on the spray. Check out the Z06 Fast List to see what times have been run (Z06 section). I would be happy to answer any questions you like.
Robert
Careful what you wish for!
Your goals for the car will greatly assist the feedback your soliciting
Staying Stock probably something in the 100-125 HP range. Type kit is a function of Wet or Dry first, then expanded to either a Nozzle, Plate, Halo (Dry ring hidden in the Air cleaner) or Directport.
Then consider supporting equipment like a Window Switch and Heater (Kit consistancy AND Safety is a function of bottle pressure), colder plugs as a minimum; other safety items like FPSS or AFR Lean/rich cutoff's, Control panel for switches etc are in the mix as well.
