28" Tire question...
Old Nov 14, 2008 | 11:14 AM
nmp27's Avatar
nmp27
Default 28" Tire question...
Sorry this probably belongs in another section, but I'm going to try some 28" slicks this weekend and I was wondering if I should even go into HPT and change the tire sizes?
Does correcting for the taller rear tire bring the wheel sensors back inline so that active handling still works?
Thanks!
Nick
Old Nov 14, 2008 | 11:27 AM
95BlueBomber's Avatar
95BlueBomber
I run 28s at the track and I dont tune it for them. The speedo is off but thats it
Old Nov 14, 2008 | 11:33 AM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
Interesting question. I would not think you need to change anything unless you want the speedo correct.
Old Nov 14, 2008 | 12:15 PM
dascorcha21's Avatar
dascorcha21
i would think since your running a taller tire and you have an A4 that it will affect your shift points since your speed sensors will be calculating the wrong speed
Old Nov 14, 2008 | 12:42 PM
Arun@ChampionMotors's Avatar
0Arun@ChampionMotors
Former Vendor
Yep-you'll need to change it for your shiftpoints bro.
Just click auto scaling
Old Nov 14, 2008 | 02:17 PM
kromberg's Avatar
kromberg
Does anyone have any rubbing/clearance problems with 28" tires?
Old Nov 14, 2008 | 02:24 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Yes, most likely depending on how fast you get to you will probably rub in fender liners.
Old Nov 14, 2008 | 02:51 PM
kromberg's Avatar
kromberg
If I remove the rear fender liners, would that provide enough clearance?
Old Nov 14, 2008 | 03:57 PM
95BlueBomber
oops... forgot about that.. i was on the six speed page
Old Nov 14, 2008 | 04:16 PM
Cruise-In V Veteran
Yes, thats what we do when we run the 28's
Old Nov 14, 2008 | 04:47 PM
obxfunn's Avatar
obxfunn
St. Jude Donor '07-'08-'09-'10
FedEx Bowl 4 St. Jude '09
Some other guys and I were talking about this in the "KB runs 10's" thread so I think its good info for guys with FI cars wanting to track the car. Our questions were more of when to go from a 26" tire to a 28" tire. I run my drag pack with 28" on the streets and as long as I have 20psi in them, they don't rub. If it gets to 14 or 15psi in the tires they do rub when I hit a good bump and they bounce a bit. I have a buddy who borrowed them on his lowered car and he now has new inners, =)
If you have never had your car at the track, which would you start with if you are at a700/700 power level? The 26" or 28"?
Old Nov 18, 2008 | 01:30 AM
nmp27's Avatar
nmp27
Keith..
Minor... MINOR rub on the center of the fender [if you are looking at the passenger side of the car, the rub on mine would be at the 2 o'clock position] about 3" tall
My car is lowered almost all the way
To 28" Tire question...
