Fuel System = bad MPG ?
Old Nov 16, 2008 | 10:43 AM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Default Fuel System = bad MPG ?
Hey guys, there wil most likely be more people with my kind of motor in here than the tech section so I need your opinions.
The motor/car setup is in my sig below and the fuel system is a LPE fuel pump, Racetronix harness, and a KB BAP. The BAP only comes on when I turn the switch on, therefor I think it can be take out of the equation. I also have RC 550cc injectors.
Before my motor swap this past summer I was getting ~18-19 MPG in the city, then after my motor swap (which is the same ci as before), I am getting 14 MPG tops. Usually its more like 12-13.....Is something wrong here? The AFR stays right at about 14.6 while cruising also.
Old Nov 16, 2008 | 12:07 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
What gears and tranny set-up ?
Old Nov 16, 2008 | 12:19 PM
Corvette-Chris
St. Jude Donor '08
Stock MN6 trans. and 3.42 rear
Old Nov 16, 2008 | 12:48 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
At first I thought it might be that you added some gears and a big stall converter.
I got say it something with the tune. 14's a little rich, but not enough to cause your king of mileage problems. I would have a reputable tuner check it all out.
Old Nov 16, 2008 | 01:04 PM
Corvette-Chris
St. Jude Donor '08
Ok thanks for the help
Old Nov 16, 2008 | 01:25 PM
madeouttaglass's Avatar
madeouttaglass
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
FWIW- When I built mine last year I also got terrible MPGs like you. The guys at ECS spent the day guessing at what it could be. They ended up agreeing that the cam (LPE) was probably not as advertised. I swapped it out for their famous blower cam (and switched from a Vortech to their Paxton- but that shouldn't matter) and it now gets almost the same mileage as when it was stock.
Old Nov 16, 2008 | 01:53 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Bro look into injectors and tuning.
Old Nov 16, 2008 | 10:27 PM
Corvette-Chris
St. Jude Donor '08
Well I had LME put the cam in and they degreed it and all so I trust that it is ok.
Are you saying that they are to big Noumin? I need them that big because I am running a dry shot also so I want to have injector to handle it ya know.
Old Nov 16, 2008 | 10:31 PM
FactoryRaceCar
What is the duty cycle on them in NA mode and while spraying? What plugs are you using? Standalone fuel cell for spray? I am almost thinking you may have to upgrade your fuel system to a return line style and a regulator.
Old Nov 16, 2008 | 10:34 PM
mdhmi's Avatar
mdhmi
My guess is the tune. 14 MPG is a joke for a stick car.
Old Nov 16, 2008 | 10:36 PM
Corvette-Chris
St. Jude Donor '08
The DC is low 30% NA and but I am in the middle of hooking up the 2nd stage dry so Im not sure about the DC on the spray.
Yeah, You may be right
Old Nov 16, 2008 | 10:42 PM
FactoryRaceCar
I would DEFINATELY let somone knowledgable in the field check your tune out. Remember what happened with your last setup and bad tune? I am more leaning towards the tune but fuel system maybe something that you want to look into.
Old Nov 16, 2008 | 10:45 PM
Corvette-Chris
St. Jude Donor '08
Yeah your right bud. That was a sad day but all smiles now
Old Nov 16, 2008 | 10:48 PM
FactoryRaceCar
I would strongly suggest NOT to spray the second stage at this point. Something is really off with your setup bro. Last thing that I would EVER want to read about.... hell I am not even gonna type it!
Old Nov 16, 2008 | 10:51 PM
Corvette-Chris
St. Jude Donor '08
No dont say it LOL
Ive sprayed the wet hit and it pulls really nicely
To Fuel System = bad MPG ?
