no clue..I cant see the belt slipping while making no boost and just freewheeling the blower. Maybe a weird internal harmonics problem in the blower. Who knows..
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Originally Posted by willig5
Glad to hear you found your problem. But I have to say I don't understand it.
very strange! We have a bunch of cars out there with the 3" pulley and never had any issue like that at all. Hell I have my car set up with the ten rib OD balancer and a 2.75" pulley!
At least it's gone though so I'll look forward to some healthy track times.
I want to pick some brains.. don't know if you saw my other posts, but I have been fighting what I thought was a high rpm miss for a few months. At about 5500-5700rpm the car feels like it has a miss(jerks) hard enough by 5800rpm you need to let off.. I went through everything New: plugs, wires, valve springs, crank sensor, checked crank sensor wires, pulled oil pan and checked reluctor wheel, etc... So the other night I was thinking outside the box..So I reved the motor up slowly in neutral with no load or boost(low cylinder pressures) and it still does it at 5700rpm...So pulled the belt off, reved the motor up slowly in neutral and the motor pulls clean and smooth to 7000rpm. Put the belt back on, pulled off the 2 bypass valves and just let the air free flow(no load on the blower) and reved it up slowly in neutral again with no load or boost and it still does it. Very weird..I'm thinking its an internal problem with the Paxton.. Chris from ECS is sending me a 3.25" pulley to test with and see if slowing the blower speed down moves the problem up in the rpm range indicating if it a head unit problem...
Well sorry for the long message guys..Any input would be helpful.
F--- ME!!!Played with it more this morning. Chris at ESC was kind enough to send me a 3.25" pulley on loan to test, so I swapped pulleys from the 3" to a 3.25" and the FN problem is gone...that only changes the blower speed by 4092rpm at 5700rpm WTF!!! Maybe I can get it on the dyno this week and see what it does under a load...
I'm sure you checked but is the bypass valve working correctly? The more I think about it, in conjunction with the rough bearings, it sounds like you may have been in surge margin of compressor... By slowing supercharger down you removed air flow and potentially opened up your surge margin. When you hit surge margin, you start with localized stalls, followed usually by full or rotating stall, then followed by flow reversal... This is violent and power input jumps up considerably (input power required is that big and can explain why your engine fell on its face), with turbo because its not mechanically coupled it slows the turbine down which does slip. Also surge causes extreme loads and vibration, which can kill bearings.
Did you hear a strange sound when you hit the wall with 3" pulley.
Maybe retest with and old pulley and just let it vent (disconnect blower discharge)... Also reving an engine with low or no load, is when bypass valve has to relieve or vent the most. What size/type bypass valve did you have.
Good luck,
Mike
Edit - did see you tried it with no BOV, but still thinking with discharge venting would be a valid test... If it still does it, then see what you can do about a replacement. Unit could have tolerance, balance, bad volute... issues, list goes on.
I tried this as well and the problem was still there...Going to put it on the dyno Sat. with the 3.25" pulley and see what happens with a load on it...
sucks..who knows...I know with the larger pulley I probably won't make the numbers I was shooting for...
Bro I hope everything works out for you! Its been a long time and I'd like to see you make some big power and enjoy your car
Just got back from the dyno..Problem is still there, you can see it in the graph starting at 6000rpm. Low boost at 13psi was the 693 and high boost was the 832 at 17-18psi...3.25" pulley and 8" overdrive balancer.. Still having the rough high rpm problem starting at 6000rpm...Changing to the 3.25" pulley just moved it up a few 100 rpm..I'm going to try and fine a shorter belt to see if its belt slip, but I don't think its belt slip..
There is belt slip, I can see it in the high rpm of the dyno graph.
Does the car still pop and studder ? The fact you took off the belt and the issue stopped leads me to believe it sounds like a charging issue.
never poped just feels like a small studder above 6000rpm...
When you see the line on the dyno get wavey like that, its usually belt or clutch slip. When you described studders, and saying it would do it out of gear with no load, I would guess ignition or charge related. The fact you took the belt off and the issue stopped would also point to the charge system. I would switch out the alternator and check for feed back in the system.
From: ECS : WTF did you break now and HTF did you break it this time
you, my friend have issues....
I think I need a OD balancer and a 2.75 now too.....
From: Ok! So you don't believe in conspiracies, but will you acknowledge the possibility of there being coordinated activities in secret places? Texas
