external waist gate location
Old Nov 27, 2008 | 07:05 AM
sultan 2 ZR1 KSA's Avatar
sultan 2 ZR1 KSA
Default external waist gate location
hi to you all i am having a dillema were do you put an external waist gate on a turbo
1- after the exouhst
2-on the headers ( colector pipe )
need your help
thanks in advance
Old Nov 27, 2008 | 10:20 AM
Chris Stewart's Avatar
Chris Stewart
Maybe this will give you the basic idea.
Old Nov 27, 2008 | 12:43 PM
George Scott's Avatar
George Scott
need your help
thanks in advance
The wastegate should be installed in the collector in front of the turbine housing. If your using just one turbo it can be installed in the crossover pipe too.
Old Nov 27, 2008 | 01:23 PM
sultan 2 ZR1 KSA
so it should be b4 the turbo in the so it can exhoust energy thus slowing the turbo down and droping boost presure or wheel rotation speed
but in the case of the photos here it is placed after the turbine housing
http://i274.photobucket.com/albums/j..._bucket/m1.jpg
is it the same idea and dose it do the same jobb ?
also this photo here
http://www.airpowersystems.com/corve...under_prod.jpg
but here i see it like you mentiond in the colector
http://www.turboxs.com/uploaded_images/464.gif
so wich one corect i am geting confused i am about to install ne turbos on my car and i need the help for the location
thanks
Old Nov 28, 2008 | 06:05 AM
sultan 2 ZR1 KSA
hay gents i need your help i am going to do it like the APS kit i need to know the advanteges and disatventeges
thanks
Old Nov 28, 2008 | 07:50 AM
chuntington101's Avatar
chuntington101
what setup is it on? what turbos are you running? is there an reson you cant run internally gated turbos?
Chris.
Old Nov 28, 2008 | 08:08 AM
sultan 2 ZR1 KSA
it is LPE and there is no space for any thing lager than a GT2871 and i am installing GT3076
Old Nov 28, 2008 | 03:01 PM
Loboost's Avatar
Loboost
The location of the wastegate is also determined buy the exhaust hsg, if it has provision for internal or external wastegates.
http://www.atpturbo.com/Merchant2/me...egory_Code=GRT
As you can see a hsg that has no provision for a wastegate passage would need the wastegate before the turbo.
Les
Old Nov 28, 2008 | 06:12 PM
sultan 2 ZR1 KSA
Les
actully what i bought was this and i am wondering haw or if i can change it external ?
http://www.atpturbo.com/Merchant2/me...egory_Code=TBO
Old Nov 28, 2008 | 06:24 PM
Loboost's Avatar
Loboost
I would contact them before you do anything they may be able to get a different turbo or hsg possibly. I do know there are not very many options for T25 flanged turbos however.
Les
I ran a pair of these on my APS GTO with a forged LS2 stock displacement and made 797 to the tire at 17psi
http://videos.streetfire.net/video/2...364_130663.htm
http://www.atpturbo.com/Merchant2/me...egory_Code=GRT I was told by ATP that this is a much more balanced turbo than the units you have, the larger compressor you have will easily put even more back pressure into the small T25 flanged turbine hsg.
Les
To external waist gate location
