Sputtering issue gone now something else need your help.
Old Nov 27, 2008 | 12:21 PM
Kamil's Avatar
Kamil
Default Sputtering issue gone now something else need your help.
Hey Guys,
About 2 months or so ago I ran into having a sputtering issue with my ignition in my Boosted Z06. The car is at 11lbs of boost with meth. I decided to do a swap on everything and went with new MSD wires, new NGK TR6 Plugs (gapped at 32), and new MSD ignition coils. When I was finished the car was amazing for about 10 miles or so. While sitting in the parking lot I heard a loud POP coming from the back right away I knew that it was the problem comng back. I drove the car around it pulled hard, at least harder than it did before I replaced everything but it was definetly breaking up, no check engine light like before. Anyone ever run into this issue? Please if you can help me out.
KAMIL
Old Nov 28, 2008 | 02:54 PM
Kamil's Avatar
Kamil
anyone?
Old Nov 28, 2008 | 04:25 PM
BUBBAS 01Z06's Avatar
BUBBAS 01Z06
Kamil...
Could it be running super rich at certain RPMs ???
Did you get a chance to log the event ??
Old Nov 28, 2008 | 09:00 PM
Kamil's Avatar
Kamil
Originally Posted by BUBBAS 01Z06
Kamil...
I think I just found the issue my wires seem to be going loose on cylinder number 1 and 2 off the spark plug. Everytime I take the car out the plugs seem to get loose (the same ones) Has anyone ever ran into this issue?
Old Nov 29, 2008 | 01:50 AM
cdn ws6's Avatar
cdn ws6
I bought MSD wires from Summit and promptly sent them back! I had the same issues with the wires not properly "clipping" on. I now run Taylor Thundervolt 8.2mm wires and they fit great. I used them on my other Z06 as well with the same success!
Old Dec 1, 2008 | 01:41 PM
HWY HNTR's Avatar
HWY HNTR
MSD wires suck. Stick with Gm or taylor.
Old Dec 1, 2008 | 06:38 PM
Kamil's Avatar
Kamil
I just checked the wires and they are not loose at all but I still get the break up. i will try my old GM wires if that does not fix the problem thn I'm done screwing with it myself and I'll take the car to the shop.
Old Dec 1, 2008 | 06:55 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Old Dec 1, 2008 | 07:03 PM
blwnc5's Avatar
blwnc5
In 2 years I used 3 or 4 sets of MSD's wires from Summit, I bought taylor and they fit much better and no issues, I also use the socks with them, When the MSD's went they would make the motor pop and miss at high rpm, Good luck.
Old Dec 1, 2008 | 07:59 PM
Kamil's Avatar
Kamil
That is exacly what is happening to the car the motor pops and misfires at higher rpms. But i just got a brand new set of MSD wires can new ones go bad after 10 miles? that is crazy. Will the old OEM GM work fine? Where would I get tylor wires?
Old Dec 1, 2008 | 08:09 PM
Vega$Vette's Avatar
Vega$Vette
I have run the same MSD wires on my SC setup for a couple of years with no problems
Old Dec 1, 2008 | 08:32 PM
HWY HNTR's Avatar
HWY HNTR
Play the lotto.
Kamil, go with taylor or stick with gm. try reusing the stock ones if you havent damaged them when you pulled them off and see what happens.
I had MSD wires on 2 of my cars and had the same issues you are having.
Old Dec 1, 2008 | 09:13 PM
Kamil's Avatar
Kamil
Play the lotto.
Thanks. Where can I get the Taylor wires???
Old Dec 2, 2008 | 08:30 AM
blwnc5's Avatar
blwnc5
Summit
To Sputtering issue gone now something else need your help.
