Performance Improvement Suggestions
Old Dec 2, 2008 | 05:30 PM
BIGMAC's Avatar
BIGMAC
Default Performance Improvement Suggestions
Please see my signature for current mods / performance. I am looking to pick up a bit more performance looking for low 11's. Lingenfelter advises I am close to being "maxed out" with the M112 S/C and would need to swap out to a M122 if I went with heads or stroker crank- I have no intentions to do that. I am running 6.5 lbs boost so I could up that a bit with a pulley. Would I need water/alcohol injection? Is there some sort of intercooler that would give cooler charge over the "stock" Magnuson set up? Any other things to consider?
I want to stay conservative and not risk blowing up the stock internals save the cam and springs. I have no interest in adding NOS.
Thanks in advance!
Old Dec 2, 2008 | 05:47 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
These would be my suggestions.
http://www.eastcoastsupercharging.co..._balancer.html
http://www.eastcoastsupercharging.co...tensioner.html
(we presently are having a sale on these)
http://www.eastcoastsupercharging.co...hol%20Kit.html
That would get you a fair amount more power, and keep you happy for a while. Feel free to call the shop tomorrow if you have any questions.
Old Dec 2, 2008 | 11:12 PM
4DRUSH's Avatar
4DRUSH
Or sell the maggie and get this
http://forums.corvetteforum.com/c5-f...installed.html
Old Dec 3, 2008 | 08:05 AM
DA GOAT!'s Avatar
DA GOAT!
You can also overdrive the 112. I had a 112 overdriven with a 2.9 pulley up front on a 402 making 14 psi on a GTO.
Old Dec 3, 2008 | 08:16 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
You can easily push that blower to 10psi. Go to Magnuson's website and look at the temperature output charts for these blowers before you push it any higher than that. I have spoken with an engineer at Magnuson about this very thing. 10psi is the max I would do after my research. One thing the Maggies love is a small shot of nitrous. John Page at 21st Century Muscle Cars has done a handful of 75 shots on these Maggies producing 600/600 at the wheels. That will get you cookin in Crisco!
Old Dec 3, 2008 | 08:50 AM
DA GOAT!'s Avatar
DA GOAT!
I was spraying a 150 shot through mine!
Old Dec 3, 2008 | 10:56 PM
FunCool's Avatar
FunCool
Thanks in advance!
You don't have to sell nothing!!! With my 112 maggie I have made 600rwh and 700rwt with 15lbs of boost. I am now making 18lbs of boost on my 402ci. Look at my signature.
Old Dec 3, 2008 | 11:28 PM
4DRUSH's Avatar
4DRUSH
Your the "King" Funtool. Their can only be one King. BIGMAC needs a Nova
Old Dec 3, 2008 | 11:33 PM
FunCool's Avatar
FunCool
I'm looking for a queen to share my throne with.
Old Dec 4, 2008 | 01:22 PM
BIGMAC's Avatar
BIGMAC
FunCool,
You are my hero.
I note you are running a fully "built" motor.
What do you estimate is the maximum boost on my "almost stock" LS1 with / without meth injection? What sort of RWHP could I expect?
Old Dec 4, 2008 | 08:16 PM
FunCool's Avatar
FunCool
FunCool,
You are my hero.
I don't know if I'm a hero, but maybe a maggie king!!!!! I think what your asking is how much boost can you run with out meth, is that right? Well you can run a 3.0 pulley ( 8-10lbs of boost )and should go 125-126mph in the 1/4 mile, about 480rwh. With a cam and meth 500rwh is easy.
Old Dec 7, 2008 | 07:37 PM
Toby Van Horn's Avatar
Toby Van Horn
If you are already running a small pulley in front, how much more boost do you see by going with the larger crank pulley?
Old Dec 7, 2008 | 09:24 PM
FunCool's Avatar
FunCool
When I put a bigger crank pulley from E.C.S I gained 2 to 3lbs of boost.
Old Dec 7, 2008 | 09:36 PM
M_T_0's Avatar
M_T_0
this is on stock 100k mile short, this is also before and after the overdrive crank pulley
Old Dec 7, 2008 | 09:38 PM
M_T_0's Avatar
M_T_0
the maggie can and will take you past the point that everything else breaks
Old Dec 7, 2008 | 09:39 PM
FunCool's Avatar
FunCool
Got to love that flat TQ!!!! May the force be with you!
To Performance Improvement Suggestions
