maggie upgrade question
I saw at ECS the 8" crank pulley, but also noticed that some people run the 2.4" S.C. pulley. I would think it would be a lot cheaper to go to change the S.C. pulley.
My first question is would the 2.4" pulley give me a noticable amount of boost?
I am running a meth cooler, and looking into converting it to a dual spray, but the tuner that has worked on this car is a little aprehensive about more boost. I am in sacramento so the summers are pretty hot, that may be part of his concern?
I am running 9:1 compression, I may be wrong, but doesn't that allow a little more boost than say one with 105 or 11:1?
I want to be able to have a fairly reliable 550RWHP car, what do you guys think, or should I just keep it the way it is?
Thanks in advance for your thoughts, and I am sure at least one of you will say trade in the maggie
thanks
I have no problems with IAT (runs around 140-160 here in south texas) @ 11.5# or so of boost on 64 cc heads (z06 level compression) and have put 30k miles on this setup.
IMO if your tuner cant make a forged 9:1 compression short block stand up to 12 psi (intercooled, if non-intercooled you will have a problem) maggie you need a better tuner.
I'm running straight water and water wetter in the intercooler (no antifreez) to get the best performance out of the IC. my tuner added extea fuel to cut back power due to the non-forged short block to cut the power back to 533 580 but with a forged short block that would not have been required.
More Than Zero
I should read things before I post them, I think it came out wrongTo clearify I meant an upgrade to an intercooled maggie or a larger / newer one ect. I love the way it drives!! I am just looking for a little more.
BTW, I was thinking about seriously thinking about purchasing the Vette that you have. It looks nice & I love the motor being forged.
You're wasting your forged motor with the underperforming Maggie.
You might want to check out Andy at A&A for your tuning as well.
I want something streetable and I love the TQ and HP #'s at 2500 - 6500 rpm.
I like knowing my motor is built for more.
It makes me feel better than the people that have more HP out of their motor than it is designed for.
Thanks for all the input! I think I am going to run a DYNO and see where I am at now, it has been a little while since that has been done.
From there I am going to fix my meth kit (probably buy a new one as this one seems to have it's issues). From everyones suggestions it seems like ECS is the way to go with that.
From there I will work with my tuner and see about the bigger crank pulley. I would like to do it, but if it required updating to an intercooled I do not know if I will do that...
I am glad you got the setup you like. With this vette I feel that the price was right, and I was bored that day so I bought it.
I do like the car, I love the fact that it is forged and a lot of CARTEK work which seems to be of pretty good quality. Between the owner in NJ and Roseville there is a lot of updated stuff (probably more than what is OE)
although you got 503rwhp I am forged I am at 9:1 compression so that would effect the HP. I will update with dyno / tune #'s. I do love the car and IMO it hauls A$$.
