Loaded question as to the wet or dry question......I like wet shots and have just finished installing a 150 wet kit on a guy's C6, a fellow member here. No fuel pump needed on otherwise stock engine and it runs hard on the squeeze!
i just dont wana blow my **** up haha, thats what im afraid of
Had my tuner install a NOS 150 WET plate system in my 01. Used it for 7 passes last month. Could have gone all night Ran out of nitrous.
EVERY pass on this cam and bolt-on only A4 car, was 10 and a half seconds.
That's right a cam, all the bolt-ons, and a 150 shot provides mid 10 second passes.
I left a touch on the table since I had the rpm/window switch cutting the nitrous about 200rpm early.
Cannot wait until next weekend when I get to flog her some more.
These LSX engines take alot.
so with the window switch i should be pretty safe right?? just since it will cut out anytime somethin goes wrong
ive seen videos of vetts on the dyno and spray blowin them up
thats just wut scares me
No The window switch allows you to preset certain perimeters into the system. On - Off RPM, Multi gear lockout, Dual stages etc. You need to have the car PROPERLY TUNED. As with any power mod, there is the possibility of something breaking.
I run a 150dry shot with a BAP & some HSW goodies.If your car is a stick you'll frag the stock clutch real quick.Hit Robert up,He's a forum vendor/nitrous guru. http://robertsnitrousservice.com/ He has lots of good advise.
i wana spray my vett but havent had the experience on it
ive sprayed the crap out of mustangs in the past but not on my 04 c5,
what are you guys spraying your stock motors at? (SAFELY)
i wana know what i should do on it
also whats better on these cars a wet or dry kit?
let me know thanks
Here's current thread from the C6 section. we talk about wet and dry, safe levels, what eledctronics are needed and many different angles, good read. Hit me up on Pm if you would like some questions answered, or on here as we all like helping. pros-and-cons-about-nitrous
Bob is so correct, these motors can handle a lot of hp given a good tune. Bob, if you want to double the runs possible check out the NANO technology. As soon as i get a chance we will be doing a NANO thread with deals on some select kits, though I may wait till after X-mas. anyway, the NANO section of my web site has all kinds of good info on NANO benefits.
Thanks for the kind words. My buddy is running the BAP on his stock C5 Walbro oump and is approaching 700rwhp, so man that BAP works wonders.
Robert
The window switch is a safety item no doubt, as you don't want to spray to early or to late, but there is more safety features out there. The electronics that will be in my kits will shut the nitrous system down should it sense anything wrong with MAF/PCM/wiring/controller, then the other controller will shut the system down based up on high and low air fuel ratios. the a/f ratio shut down feature is the best one as going lean is the normal reason for backfires and engine bay burn downs. These two products, the Interface and MicroEdge are covered in the link in the prior post and complete info on my site.
Robert
I am planning on going to the NANO system in February. Need to raise a few bucks. I'll be sure to give you a call.
Thanks Buddy. Did you see that i have one of your bottle mount pictures hosted?
Blk Btty C5, when I first got my '97 coupe, i started with a basic dry kit, the NOS 5177. Once I had the base kit we changed up and added on in so many ways. First major change was going to dual stage, but the point is, after getting a basic kit you can always add on and make changes. That is one of the reasons I love nitrous so much, it's always evolving and changing, so for those that like to tinker around there is many things that can be done. Today, from that basic dry kit I am probably close to 10 different dry set-ups on my '97 and Z06 and still have less $$ than a blower or turbo. Still running many of the original parts too and now it's morphed into a 3-stage with a Direct port dry as stage one. I guess what i am saying is, you could do a single stage kit the way you like and be done with it, or the same kit can grow over a period of time as the money allows. I just added a NANO set-up as my last mod a couple weeks ago, so the evolution is still in progress.
Robert
