STS kit question
would this work on a 01 ZO6? that would be the car it going on, I already have injectors and fuel pump on car so thats not an issue
I was thinking of this bc there is a huge price difference between the C5 kit and the universal kit
$2995 compared to around $7000
thanks in advance
If you're going to buy a 'kit' that you have to actually cut/weld into the piping/etc, you might as well start from scratch. Snag a PT67 for $700-800, grab a 'knock-off' BOV and wastegate (they work well, surprisingly enough... and are dirt cheap), an oil-pump, vac-lines, oil-lines and fittings, a cheap I/C from 'that auction site,' and so on...
Basically, if you're going to attempt to build it, just build it from scratch. Why pay the mark-up fee that STS is going to charge you? They have to make money to keep the doors open that that 'mark up' fee is what you could avoid by doing your homework, acquiring the parts on your own. Unless I'm mistaken by the 'universal' kit, you'll have to do the same amount of work when building your system.
Also... whatever you think it's going to cost... add 50%... if not 100%. These things get out of hand
but if I did decide to go with the universal kit would just that single t3/t4 turbo really do anything on my car?
or would I have to go with a bigger turbo regardless or go with the twin t3/t4 setup?
I would really like to keep in rear mounted
Turbo (application specific)
Wastegate, 38mm
Wastegate Pipe
Wiring Harness
Silicone Kit
Air Filter
Dry-charger
Hose Kit
Clamp Kit
Turbo Flange Kit
Bolt Kit
Brass Kit
Oil Pump
Oil Check Valve
Pipe Kit
PCV System
Pressure Switch
Instruction Manual
And by all means the electric scavenge pumps will work but why not run a single or dual scavenge pump for the oil return. You will want rear end style pump like they use on race to circulate and cool rear ends. If you need to buy an electric pump if you don't go with STS RB Racing sells them.
Again if you want a single go to LS1tech.com and ask for advice, good people there. If you want dual STS appears to use a stage 3 T3 turbine which is a 2.559" major and a 2.229" minor diameter turbine wheel. For compressor stay with the TO4E series compressors don't go to TO4B. The E's are much better with compressor efficiency and will give more room to grow if you decide you want more. The GT series turbo would be even better, and the best would probably be Borg Warner series turbo but they get expensive. A 50 or 54 trim E compressor would probably be a good choice if you want about 500 to 600 hp flywheel.
Anyway good luck with what ever you do, if I have enough funds I will be doing my own rear mount setup soon. I will be using a 2 stage dry sump pump driven off the motor since they are dead reliable, none of this electric stuff for me even though they have been reported to work very well. Also learn what you can about turbocharging and airflow requirements. By a book on turbocharging, it will be necessary. By the way this was a quick rundown feel free to ask more questions. And don't forget about the intercooler!
