Racetronix, BAP, or Both?
Will the Racetronix harness suffice?
What kind of pressure should I maintain as a normal, and what is the minumum pressure that should be monitored for?
my tuner/installer (Fran - Race Proven Motorsports) had already installed the LPE Fuel Pump for me. He then added a KB BAP and the RaceTronix Harness.... i am now anywhere between 61-65 psi all of the time, no drop off in Fuel Pressure...
60 lbs rock steady at idle and cruising/light throttle
52-58 going through the gears "normal" driving shifting at 3500-5500 out of boost
Once in boost the pressure begins dropping FAST
50-40 WOT from 2-4 psi
40-30 WOT from 4-9 psi
AFR's are fine so I guess even having low pressure can be tuned for. I'm at 60 psi idle and cruising and drops to 30 psi WOT at 8-9 psi and 550 rwhp and have been for the past 3500 hard driven miles. Kinda baffling it can work like that and I don't like it so im gonna get the pressure where most peoples are and re-tune.
Early morning run, first run of the day about 10am in cool air: started the run at 61psi, finish about 51, ambient temp 65 degrees F.
Afternoon run, after a few passes and temps getting hot outside: started the run at 52psi, finish about 46, ambient temp 79 degrees F.
You're going fairly fast and making good power.Why don't you have an after market pump?
The harness will up the voltage but under BOOST the BAP will make sure it gets the extra voltage while sustaining BOOST!
IMHO! Only
Thanks,Matt
Im only asking because this is what I have, and Im getting tired of the Nitrous stuff and was thinking about going FI.
Now with the forged motor, and all the above (without the A&A fuel system) I was running out of fuel in mid 700s. After adding A&A fuel system (boost referenced) along with LPE Intank pump, KB BAP and Racetronix harness, I have enough fuel for 1000+ rwhp.
So my system currently has the Racetronics pump/hot wire, return and reg at the rails, then a complete "Parallel" Andy style aux fuel system. My Racetronics system started running out of fuel around the 550/600hp area and thus the reason for going Parallel system. We absolutely do not want pressure drop at high demand when spraying, as we all know what lean and spraying can do.
The one thing that can be done to stop the pressure drop in high load conditions is to get the regulator/return at the rails (which Andy's kit does). Some guys fudge the tune to compensate, however the correct fix is getting the reg and return at the rails and having adequate supply.
Here's a picture of one of the A&A kits I carry, and couple more are being added. Watch for the new billet dual pump hanger/kits from RSI to be added in a few days. Also a full line of stand alone fuel systems are coming. The link is a write up on our fuel systems and modding them, and it should offer some good insight into what you may want to do (Andy's kit has a great how-to step by step install manual).
Csdunaway, the write up covers my early mods and limits and why and when I upgraded from there. So you may be able to map out your needs and contains some math for sizing your system. If you have any questions I am always available. The parts you have may be enough, though watching your fuel pressure and a/f ratio will be your best indicators.
Fuel System Up-Grading
Robert
