can I use nitrous??
I just added a 100 wet shot the other day. It definately made a good difference and I dont even have my bottle heater, bottle pressure was way low.
I plan to get a tune and up the shot higher. I mainly did 100 to test the system and have it installed. I did it on stock TR5 plugs, pulled over checked the plugs, and they were perfect. I since added TR6(1 step colder) to be on the safe side.
The Safe limit ends at 600rwhp no matter what way you slice it, boost, spray with these bottom ends Ive been on the nitrous forum at ls1tech. Theres some guys that are running heads and cam and a 200 shot at arround 750hp is the record for the stock bottom end.
they are renegades though and not scared of what could happen.
My personal plan is a 150-175shot(race day only) With proper tuning-timing to do the 175, and I dont plan on doing it allot to keep longativity.
Theres a guy named mark murillo that has a black c5 z06, Heads cam 175 shot on stock bottom end running 9's So the potential is there if you chose to stop modding with after you add spray.
If 100shot fits your fancy, Its pretty safe and should last you a long time, and you should be able to squeeze it out of your stock fuel system, though id add a fuel pressure safety switch just incase.
My personal setup will have a 255lph fuel pump, Racetronix hotwire harness,Bigger inecjors (not an necessity with a wet kit but im getting some anyhow)a Fjo progressive controller, and a good bottle warmer and tune
Nick
Stick with a 100 shot.
Go wet if you don't want to mess with your injectors. (although dry is safer IMO)
tune (or wideband monitoring) is pretty essential.
If anything did go wrong, it would have gone wrong anyway.. just a little later than it did.
I'll admit Im not expert on the matter ( and frankly a "noob" on these forums
), but ive been around at least 5 good buddies cars all on spray. 3 or 4 had them professionally installed, and when they asked the experts their, all of them said to not go beyond a 125 shot. Disregarding possible danger, unless your vette can hold up to that much more power at the flywheel, i would suggest an adjustible 75-125 wet shot.This is a kit recommended for an LS1 (u got an ls1?)
http://www.atlanticspeed.com/product...gory=0#details
About the other buddy that installed a 200 shot on his '98 Z28 (had exhaust,heads,intake,lowered). It was fun hitting mid-11s on the quarter, but those engines arnt meant to take that and hes had to replace his clutch, flywheel and un-install his kit he had spent a good installing
and trust me...125 shot makes a BIG difference...i like to think of it as a second engine
I have sprayed the crap out of my 100% stock LS6, over 300 1/4 mile passes, at upto 250rwhp shot. I finally bent a rod and broke a ring land with a 285rwhp shot on the dyno, but still won the dyno trophy for sprayed cars, lol. Multi staging is the answer.
Here's a link from the C6 section, though applies equally to the C5. I think you can garner much insight from this thread. The key to a nice size shot is to break up the torque a little bit. The sprayed high HP motors that actually live a long life are for the most part multi staged to control the torque on the botton end at lower rpms. Let me know if I can help in any way.
pros-and-cons-about-nitrous-on-a-c6
Robert
I have 58,000 miles on my 2001 Coupe. Many of them 1/4 mile at a time.
I currently have a 150 wet shot using the NOS plate. I have only run a few dozen passes with the nitrous but I notice nothing out of the ordinary with the motor.
This is being done with the STOCK fuel system.
Robert
I pm'd you a couple weeks ago to get some help with a nitrous setup/some advice and was wondering if you could shoot me one back...the Z is begging for a bottle
Robert
yeah man the LS1 eats that nos up like no other
