C5 fuel system gurus
Old Jan 26, 2009 | 08:05 PM
Brandon619's Avatar
Brandon619
Default C5 fuel system gurus
Ok I've install a custom fuel system on my C5 for my added power. Now, I'm using a Aeromotive pump with - 10 line form the drivers side tank and using my old feed line as a return line. I'm having problems with the right side tank pumping over to my left hand tank. I've studied the GM manuals I have and it shows that the left tank has a jet pump that pumps over to my right hand tank. Now that I'm running a external pump it's not providing pressure to the jet pump from the left tank to level my fuel out. Has anyone encountered this problem with a custom fuel system with a external pump? Oh also I have all of the feed lines and crossover lines hooked up from the left tank to the right tank if the explains alittle more. Any knowledge would help me out alot
Old Jan 27, 2009 | 08:14 AM
sultan 2 ZR1 KSA's Avatar
sultan 2 ZR1 KSA
intresting problem , i am running almost the same system with defrince brands , i think your jet pump might be damaged , have some one take a look at it
Old Jan 27, 2009 | 09:22 AM
exploder's Avatar
exploder
I have a similar problem...with a few differences. I have an identical fuel system with an external pump, but I also added 96lb. low impedence injectors. I then turned the fuel pressure down to compensate for the larger injectors and to make it easier to tune. In doing so I guess dropping the pressure caused the jet pump not to work correctly and will not let me fill the car over half of a tank. The fuel gauge still shows full, but there is actually only fuel in the drivers tank. As soon as I get to half empty on my gauge the car runs out of gas and dies. I spoke to lingenfelter the other day and they make two little fuel pressure block offs that bypass the factory fuel pressure regulators in both tanks and should allow me to run at a lower pressure and use both tanks. I don't know if any of this is beneficial to you or not, but it is all I know. You didn't mention what year your car was, but using context clues I am guessing it is a 03 or up with the FFS system like mine.
This may also be helpful...
http://www.corvetteactioncenter.com/...el+Tank+System
Old Jan 27, 2009 | 09:23 AM
Brandon619's Avatar
Brandon619
well the problem is that when I get around half tank my gauge goes to empty. I think I might tap my right hand tank with a -10 fitting and run it to the suction side of my fuel pump.
Old Jan 27, 2009 | 10:58 AM
Brandon619's Avatar
Brandon619
2001 z06
Old Jan 27, 2009 | 12:09 PM
HP_Addict's Avatar
HP_Addict
Are you sure it is not just the fuel level sender going out? They are prone to act erratic.
Old Jan 27, 2009 | 01:02 PM
Brandon619's Avatar
Brandon619
That could be the case, when this problem first happened to me I was on a full tank then when it passed the half tank mark it went to empty. I still drove on it for about 40 plus miles with no issue. So I thought my jet pump from the left tank was not feeding my right tank. When I made the mod to my sending unit I left the float of level indicator as is so this may be the problem.
Old Jan 27, 2009 | 01:33 PM
Brandon619's Avatar
Brandon619
Hey exploder that was a great link, Thank for posting that great info.
Old Jan 27, 2009 | 02:01 PM
exploder's Avatar
exploder
no problem...now come fix mine and we can call it even.
Old Jan 27, 2009 | 02:08 PM
glennd's Avatar
glennd
I tried doing a boost referenced system on my late 03 Z06. I have a bosch internal pump and a Walbro ext. The system is a return system. All has worked fine for a couple of years, 800+rwhp. When I decided to up in injector size and change over to a boost referenced system, I ran into some problems. I turned down the pressure regulator and boost referenced the regulator. When there is less than 45-50 lbs pressure the siphon pump stops working, hence the gas from the passenger side does not transfer to the drivers tank. Turning the fuel pressure back to 58 psi and not boost referencing corrected the problem.
Old Jan 27, 2009 | 02:26 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
There has been a bunch of post about this problem, try doing a search ? It has to do with the 58PSI pressure needed.
Hope you get it figured out.
Old Jan 27, 2009 | 03:14 PM
preston's Avatar
preston
If your aero pump is external that it won't work period, as the siphon pump isn't getting any pressure from an external pump. Since you are using the feed line as a return line then I don't see how it can work at all, since the siphon pump gets its pressure from the supply line. In the later model vette this is all occurring inside the tank itself, so without knowing more about your system I would say it just plain won't work.
Iif you don't want to redo your fuel system to work with the stock internal bucket and lines - build a crossover line at the bottom of the tanks. You cannot do what you said, which is add a feed line from the pass tank to your aero pump because as soon as one tank goes dry the pump will starve. I know its counter intuitive, you would think the tank with the fluid would have a pressure head and this would feed the pump instead of the dry tank, but instaed the pump sucks from the easiest source which is the empty tank.
So a crossover line is probably your best bet. Unless I misunderstand what you have done, but what I envision is no in tank pump and simply a feed line into your external aero pump.
Old Jan 27, 2009 | 03:23 PM
preston's Avatar
preston
You know this is interesting - the feed for the siphon pump goes through a regulator and then a pinhole to the pump. I always just figured that the regulator was needed to keep the flow low and not bleed off pressure from teh main pump. But it already has the pinhole restrictor. The 2ndary regulator may just be there to prevent any fuel transfer when the pressure gets low like in the case of a failing pump....The siphon pump can't be dependent on the regulated pressure to work because it is on the low side of that regulator. So, really that regulator isn't even needed, unless someone can explain to me why ?
This is important because if you remove that regulator, then you no longer have to keep your base fuel pressure so high, which is beneficial to people running boost. If you require your base pressure under motor running high vacuum conditions to be 58 psi for fuel transfer to cocur, that means your static pressure with engine off needs to be about 65 psi, which means under 15 psi of boost you have 80 psi fuel pressure, which is obviously much harder for the fuel pumps to meet the flow requirements.
Can anyone tell me why the 2nd regulatro before the siphon pump is used ?
Old Jan 27, 2009 | 08:26 PM
Brandon619's Avatar
Brandon619
Good point preston, I think I have two options the first one is a long shot. Inside the right tank where the jet pump is a check valve I was hoping if I removed it both tanks would just levels out? The second one is to just run a -10 line from that tank to the suction side of my pump. I just want to get all the info I could before ripping into the other tank.
Old Jan 28, 2009 | 09:31 PM
Steve'01's Avatar
Steve'01
Default Just an idea
I run a Y block (pump in 8, out 8 and 6 to pass tank) with a filled 6 AN fitting that I drilled out to feed the surge pump on the Pass side. I measured the small hole in the stock plastic Y and drilled out my replacement Y fitting. If you lower your pressure perhaps a larger hole will allow additional fuel to flow to properly work the surge pump? I am no mathematic genus but if you decrease pressure say 10% from stock perhaps a 10% larger hole?
Old Jan 28, 2009 | 09:51 PM
Brandon619's Avatar
Brandon619
I'm currently running a y setup to my pass tank but it is -6 . I was hoping that if I duplicated the stock setup and increase the diameter of the line that it would flow better? I'm close to just tapping a -10 fitting from the pass sending unit or access hole and running it to my pump. Thanks for the info Steve
Old Jan 29, 2009 | 02:12 AM
preston's Avatar
preston
Maybe you didn't pick that up from my post but I'm saying that will NOT work. YOu have to run that -10 line into the drivers tank. If you bring it straight to the pump or even tee it into the line feeding the pump, the pump will run dry when one tank runs dry even if there is fuel in the other tank. And this will happen no matter how you run the return line.
Your best bet is to tee a -6 line off the pump OUTLET, and run that intot he passenger tank to drive the jet pump. Put an old carb jet in there as a restrictor, not sure what size but you're looking at ~.045 hole stock. Actually this restrictor might not be required since the jet pump already has a pinhole orifice. You'll need a 5/16" hose barb to 3/8 npt, a double female npt coupler, and a 3/8npt to -6 hose inside the tank to connect to the stock jet pump hose. . Also, you must use teflon SS line or some other type of fuel immersion hose once you are insie the tank itself. Look for aeroquip teflon fittings and hose at summit, Summit has them up to -8 now. In fact all braided AN type hose that handles fuel should be teflon if you don't want it to weep a smell. You could also transition from -6 to fuel hose at the bulkhead inteface, however you want to do it.
To C5 fuel system gurus
Old Feb 1, 2009 | 10:35 PM
breecher_7's Avatar
breecher_7
Ok, toss me some insight here.
I am in the process of trying to unscrew a 2002 Z06 corvette that belongs to a friend and was hacked up by some fool.
Anyways, the old fuel system was two in tank 340 pumps, modified factory fuel hat with two -6 lines coming out of it to a y block and into one -8 line that ran up to the fuel rails then to a regulator and back to the tank. On that block, there was another discharge line that went to the siphon pump in the right tank. It worked, it transferred fuel. Problem was, because of that line running off the fuel supply y block the fuel pressure would fluctuate nearly 10psi at the rails because of that bleed off. This is not acceptable. I have no re-routed the system. I removed the fitting from the y block and plugged it. So now the supply goes to the rails and no where else. Then I took the return line that was running to the tank and ran it to the siphon pump. Now my question is, with a static 60psi at the rails and under boost creeping to 80psi will the pressure coming off the return have enough power to power that siphon pump? If not, I need a fix for this.
Old Feb 2, 2009 | 01:20 AM
preston's Avatar
preston
No, the siphon pump needs pressurized fuel and the return line shouldn't have pressure in it. People have been saying it needs 58 psi to work properly but I was just out testing one literally today and it transferred quite a bit of fuel as low as 42 psi. However while I am using the stock pump, check valve, and regulator, the rest of my system is not stock and may operate differently than a stock fuel system.
The point is that fuel coming from return line shuoldn't have any pressure and wno't drive the jet pump.
But in this case you may have bigger problems than that - AS I understand it you connected the primary return line from the front mounted regulator to the siphon pump inlet ? That seems to me like your virtually deadheading the pump as very little fuel flows through the jet pump. I would think if you actually connected it like this your primary fuel pressure would shoot way way up . You'll have to explain better what you did because the car would not run like this.
The way it was connected in the first place seems correct to me, it should not have resulted in 10 psi fluctuations at the rail. Perhaps you ahve a leak that only shows up under higher pressure ? That's how my system is ran - a -8 line off each pump to an intank y-block with a 1/8 npt port feeding a -6 line that attaches to the jet pump with a bunch of adapters, and a -6 transfer line back to the first tank. Another -8 comes out of the y-block and goes to the engine. I do not see any pressure fluctuations. The jet pump has a tiny feed orifice and an inline regulator, it should not be bleeding off any significant amount of fuel, not enough to create pressure swings of 10psi.
Old Feb 2, 2009 | 06:50 AM
breecher_7's Avatar
breecher_7
But in this case you may have bigger problems than that - AS I understand it you connected the primary return line from the front mounted regulator to the siphon pump inlet ? That seems to me like your virtually deadheading the pump as very little fuel flows through the jet pump. I would think if you actually connected it like this your primary fuel pressure would shoot way way up . You'll have to explain better what you did because the car would not run like this. Do you have any photos of your fuel system?
The fuel return line has approximatly 30psi of of fuel pressure on the return side from what I can tell at normal operating load. But if your saing it takes nearly 60psi to power the siphon so I guess I will have to look back into this further.....
