more boost
Old Jan 26, 2009 | 08:11 PM
vmantoo's Avatar
vmantoo
Default more boost
I have a question about the tune I have in my car now. I am running the maggie with 5lbs of boost. My tune is one that Lingenfelter installed. If I go with a smaller pulley for more boost, say 7 to 8lbs, would I be ok with the tune I have or would I need a tune for the boost increase? I didn't know if I should have asked this in the tune section or the FI section , so if this is not in the right place, sorry.
Last edited by vmantoo; Jan 26, 2009 at 08:47 PM. Reason: not sure I put it in the right place
Old Jan 27, 2009 | 10:44 AM
whitelite's Avatar
whitelite
Old Jan 27, 2009 | 11:37 AM
EVLZ06's Avatar
EVLZ06
More than likely you will need to adjust the tune.....probably add some fuel.
Old Jan 27, 2009 | 09:49 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
You must get a re-tune for the new B@@ST!
Worse case scenario: More air and less fuel will create a lean condition and will melt your pistons and rings.
When you add more air to the motor especially Forced Induction (as compared to NA) and you do not supply fuel to it then it will run extremely "HOT" - air added to flames (Internal combustion) will increase the heat and explosivness therfore "DETONATING" and blowing the motor.
It's like what my friend did with his Nitrous - he had a few drinks in the pit area with his car and he asked me to run his car for him, I agreed but in no way am I taking responsibility for a blown motor - agreed! - I did a nice pass and pulled into the pits and he said that was awesome, then he popped the hood and unbenounced to me he installed bigger Nitrous jets(He wanted to see it go faster) - He also neglected to install the extra fuel jets (Left them at home) and did not tell me and he asked me to run it again.
so at this point I take it down the track and "B@@M" - there was no way the motor's fuel system, injectors, MAF or anything could compensate for the extra 75 HP jets he installed!
Thus a loss of a good motor! REMEMBER Nitrous is Forced Induction
Get a re-tune you'll be glad you did in the long run
Thanks,Matt
Old Jan 27, 2009 | 10:14 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Shorter version=
Get a retune.
Old Jan 27, 2009 | 10:35 PM
TheDingo's Avatar
TheDingo
+2 get a re-tune.
Old Jan 28, 2009 | 07:24 PM
vmantoo's Avatar
vmantoo
Thanks for the replies. If I increase boost I will get a new tune.
To more boost
