octane boost
Old Feb 1, 2009 | 01:37 PM
Toby Van Horn's Avatar
Toby Van Horn
Default octane boost
I see people talking about mixing prem and racing gas, my question is what is better:
Mixing racing / 91?
Octane boost?
And are some octane boost better than others?
Getting a meth kit soon, but considering some immediate options.
Old Feb 1, 2009 | 01:40 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
If you just want somethin easy to put in your tank, use Torco.
Old Feb 1, 2009 | 10:19 PM
briann510's Avatar
briann510
Here is a nice octane blending calculator that will also tell you if its cheaper to blend pump 91 with racing gas or use the Torco booster depending on what octane you need. I prefer blending racing gas myself because I know EXACTLY whats in it and exactly what my final octane result will be. Torco of course is easier to just dump the bottle in for most people though.
Adding other chemicals to raise it also affects things other than octane so I don't go there.
http://www.ranney.com/mjr/fuel_blend.html
Old Feb 1, 2009 | 10:32 PM
nuck's Avatar
nuck
Taken from another board, but these home brew recipes are well circulated. Here also is a product comparison for bottled products including Torco. http://volvospeed.com/Reviews/octane_boosters.html
some well known formulas to make race (high octane) gas
(I take no responsibility)
Formula #1 - Toluene
R+M/2.........114
Cost...........$2.50/gal
Mixtures with 92 Octane Premium
10%...........94.2 Octane
20%...........96.4 Octane
30%...........98.6 Octane
Notes: Common ingredient in Octane Boosters in a can. 12-16 ounces will only raise octane 2-3 *points*, i.e. from 92 to 92.3. Often costs $3-5 for 12-16 ounces, when it can be purchased for less than $3/gal at chemical supply houses or paint stores.
Formula #2 - Xylene
R+M/2.........117
Cost...........$2.75/gal
10%...........94.5 Octane
20%...........97.0 Octane
30%...........99.5 Octane
Notes: Similar to Toluene. 12-16 ounces will only raise octane 2-3 *points*, i.e. from 92 to 92.3. Usually mixed with Toluene and advertised as *race formula*.
Formula #3 - Methyl-tertiary-butyl-ether (MTBE)
R+M/2.........118
Cost...........$3.50/gal
10%...........94.6 Octane
20%...........97.2 Octane
30%...........99.8 Octane
Notes: Oxygenate. Very common in octane booster products. Has lower BTU content than toluene or xylene, but oxygenate effect makes the gasoline burn better and produce more energy.
Formula #4 - Methanol or Ethanol
R+M/2.........101
Cost...........$0.60 - $1.75/gal
10%...........94.3 Octane (Methanol)
10%...........94.7 Octane (Ethanol)
20%...........Not Recommended
Notes: Methanol is wood alcohol. Ethanol is grain alcohol and found in Gasohol in 10% ratios. Both alcohols are mildly corrosive and will eat gas tank linings, rubber and aluminum if used in excessive ratios. Main ingredient in "Gas Dryers", combine with water.
Formula #5 - Isopropyl Alcohol and Tertiary Butyl Alcohol
R+M/2.........101
Cost...........$0.60-$1.50/gal
30%...........Not Recommended
Notes: Similar to Methanol/Ethanol. Isopropyl Alcohol is simply rubbing alcohol.
Sample Mixture
To make your own octane booster, it is easiest to make up a large batch, and then bottle it up in "dosage-size" uses.
Below is the basic formula of one of the popular octane booster products. To make eight 16 ounce bottles (128 oz = 1 gal):
100 oz of toluene for octane boost
25 oz of mineral spirits (cleaning agent)
3 oz of transmission fluid (lubricating agent)
This product is advertised as "octane booster with cleaning agent *and* lubricating agent!". Diesel fuel or kerosene can be substituted for mineral spirits and light turbine oil can be substituted for transmission fluid. Color can be added with petroleum dyes.
Old Feb 1, 2009 | 10:40 PM
briann510's Avatar
briann510
Toluene is friggin expensive around here at $22+/gallon at all the paint/hardware stores I checked for it. Its much cheaper to buy racing gas and mix it at least while pump 91 gas is at $2 a gallon..
Old Feb 2, 2009 | 02:05 AM
jbsblownc5's Avatar
jbsblownc5
2017 C5 of the Year Finalist
St. Jude Donor '08
Works for me for the last 6 years, no ill effects!
JB
To octane boost
