Headgaskets for TT ?
Old Feb 6, 2009 | 12:28 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Default Headgaskets for TT ?
I tried a search and couldnt really find what I was looking for.
What is the best headgaskets for a twin turbo setup that will see pretty high boost? Cometic? Stock MLS? Fel-Pro MLS?
Old Feb 6, 2009 | 12:31 PM
R6_C5_CLS55's Avatar
R6_C5_CLS55
I run the GM LS3 MLS gaskets on my SC Vette w/ LS2 block and AFR 225 heads.
Old Feb 6, 2009 | 12:35 PM
Corvette-Chris
St. Jude Donor '08
How much psi are you pushing?
Old Feb 6, 2009 | 12:44 PM
R6_C5_CLS55
I have run as much as 18 PSI without lift / leak issues. I do also have 7/16 inch C5R multiphase head studs from Katech at 95 ft-lbf (Time Sert thread conversion in block to accept 7/16 threads).
I definitely recommend the GM multi-layer steel gasket in the correct bore size for your application (make sure you consider the combustion chamber diameter of your heads in addition to the cylinder bore). I ran the SCE Titan ICS gaskets initially and they leaked water at over 18 PSI (19.4) after several passes. I did run the SCE gaskets with Yamabond #4 around the water courses, heat cycled them with no water, and retorqued the head studs before adding water and making passes, so I think I did everything I could to help them not leak under extreme cylinder pressure.
Old Feb 6, 2009 | 12:50 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
I'm going to be running cometic gaskets at around 14 PSI on my LS3 short/317 head setup. Hoping not to run into any issues.
Old Feb 6, 2009 | 01:09 PM
breecher_7's Avatar
breecher_7
Ran cometic last year with head studs and o-ring heads, no issues.
Old Feb 6, 2009 | 02:56 PM
95vettski's Avatar
95vettski
What's the bore size on those gaskets? Are your AFR heads the small bore?
Old Feb 6, 2009 | 03:36 PM
Corvette-Chris
St. Jude Donor '08
I will most likely see more than 14-16 psi EVENTUALLY so I wanna prepare for that.
Old Feb 6, 2009 | 04:47 PM
AlwaysInBoost's Avatar
AlwaysInBoost
I'm running an OEM GM 5 layer MLS gasket with ARP studs.
Arun@ChampionMotors's Avatar
0Arun@ChampionMotors
Former Vendor
I like the Fel-pro's, there a 4 layer with a nice tacky surface, your only supposed to open the package when your ready to use them. The GM MLS are all good too and for the price they just cannot be beat. Just make sure to use the correct sized bore gasket for head your using.
Old Feb 6, 2009 | 04:55 PM
R6_C5_CLS55
The bore size on the GM LS3 gasket is 4.100 inches. Also note it is a 5-layer steel gasket (as opposed to the 3-layer GM LS2 MLS gasket). I believe the gasket thickness is 0.051 inch.
My AFR heads are the 225s, which are the larger than the 205s. I did have the heads milled a bit from 72cc down to 67cc to bring the SCR up to 8.9:1 since I am using -30cc Wiseco coated pistons.
Old Feb 6, 2009 | 05:02 PM
Corvette-Chris
St. Jude Donor '08
I'll be using 317 heads on an ls1 block...do I need 3.905" or the large bore gaskets?
Old Feb 6, 2009 | 06:20 PM
95vettski's Avatar
95vettski
I was under the impression that with the AFR 225's you need to use a gasket with a minimum bore size of 4.125 according to AFR? This unshrouds the valves and prevents possible detonation.
Old Feb 6, 2009 | 09:21 PM
R6_C5_CLS55
What happens to the combustion chamber diameter when you mill the heads to reduce the combustion chamber volume from 72cc to 67cc?
Also, I used a 0.051 inch thick gasket and not a 0.040 inch thick gasket.
We did measure and test fit the gaskets on the heads before installing them.
Old Feb 7, 2009 | 12:23 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Not saying you're wrong, but it doesn't make any sense to me. The gasket should only be as large or a little larger than the bore. If the bore is 3.905 and you have a 4.125 gasket, the shrouding is going to come from the cylinder walls.
For the record, I am running 18psi on MLS with ARP studs with no issues.
Old Feb 7, 2009 | 12:27 AM
Former Vendor
Use a 6.0L gasket and you'll be fine.
Old Feb 7, 2009 | 12:30 AM
Former Vendor
Gasket needs to be bigger than the chamber, AFR 225's have a 4.125 chamber. If the gasket hangs inside the chamber then this can lead to a possible hot spot and detonate. BUT, I have seen cars use the wrong size gasket an have no issues-alot change when your FI.
To Headgaskets for TT ?
Old Feb 7, 2009 | 08:27 AM
Corvette-Chris
St. Jude Donor '08
Thanks Bret and Arun. Thats what I was looking for
Old Feb 7, 2009 | 08:34 AM
BLOWNZO6's Avatar
BLOWNZO6
Premium Supporting Vendor
I use stock GM gaskets everything...
__________________
EAST COAST SUPERCHARGING SALES AND TECH SUPPORT
WWW.EASTCOASTSUPERCHARGING.COM
Old Feb 7, 2009 | 10:42 AM
Corvette-Chris
St. Jude Donor '08
This last time around I used Cometic, didnt have any problems, but I never have with the GM stuff before either. I will stick with the GM MLS stuff.
Anyone know the part number for the 5 layer gasket?
