high idle
Old Feb 6, 2009 | 08:18 PM
Toby Van Horn's Avatar
Toby Van Horn
Default high idle
I had a question about idle. When my car is idleing it is around 900rpm, if I am driving and put it in neutral or am shifting gears it wants to hang around 2,000 rpms. Is this setup in the tune, or does it have to do with a vacuum leak ect? Vacuum and boost readings seem to be normal and do not change much.
Old Feb 7, 2009 | 09:11 AM
clif's Avatar
clif
St. Jude Donor '09-'10
What has changed in your setup? Did you replace anything like the intake, or the throttle body?
Old Feb 7, 2009 | 10:58 AM
Toby Van Horn
it has done this since I purchased it, has a maggie, and other stuff.
Old Feb 10, 2009 | 08:29 PM
hpcubed's Avatar
hpcubed
Most likely it's in the tune. There are tables that control it - ie throttle cracker/throttle follower etc.
To high idle
