Restrictor plates…are they
Old Feb 6, 2009 | 09:16 PM
LV Vette's Avatar
LV Vette
St. Jude Donor '08
Default Restrictor plates…are they
safe when using them to restrict airflow at higher rpms? I am thinking of using a restictor plate to prevent the boost from going over 6 psi on my procharged Vette. Without anything, it will go as high as 11psi at 6,500rpm. Will this cause any harm to my motor or supercharger, or should I pulley up? Also, if I go from a 3.85” pulley to a 4.1”, do I need a retune?
Clayton
Old Feb 6, 2009 | 09:26 PM
HP_Addict's Avatar
HP_Addict
Restrictor plates definitely work. We did a lot of experimenting with different size plats when I went down in pulley size. Without the restrictor my car see 16 psi and 750 rwhp, with the restrictor I see 13 psi and 650 rwhp. The best part is I lost nothing on the bottom and mid range. The airflow just gets limited at the top end. In my case above about 5500 RPMs. I would say go with the smaller pulley and run a restrictor.
Old Feb 7, 2009 | 12:37 AM
LV Vette's Avatar
LV Vette
St. Jude Donor '08
This the answer I was hoping for. Just want to make sure it is not hurting my engine by restricting the airflow.
Clayton
Old Feb 7, 2009 | 07:50 AM
2003VETT's Avatar
2003VETT
From: Still the Fastest (still running) Stock Bottom End Blown LS1/ 2010 ECS CC 10.50 CHAMP Hamilton, NJ
I have been using different restrictor plates for 4 years. They work...
Old Feb 7, 2009 | 10:34 PM
N4cer's Avatar
N4cer
Why do that? Just limit your RPMs and have a better powerband until then compared to a restrictor that'll fall off by then anyway.
Old Feb 7, 2009 | 11:20 PM
undertaker's Avatar
undertaker
From: ECS : WTF did you break now and HTF did you break it this time
because the cam and powerband of the average vette motor wants it to spend some time higher in the RPM band....
now if you had an overdrive crank pulley and a tiny blower pulley on a motor cammed for low end and midrange.....then I could see limiting things based on RPM
Old Feb 8, 2009 | 07:00 AM
clemsondave's Avatar
clemsondave
Curious which blower you have that will reach 11# with a 3.85 pulley? I have a 3.8" on a P1 and getting just over 9#. I think you will be fine at 9-10#, just pull some back on timing.
Old Feb 8, 2009 | 09:08 AM
2003VETT's Avatar
2003VETT
Because at 4500rpm I will see 13 lbs of boost. (stock bottom) and it keeps the boost consistant through the rpm range.
So I would have to set the limiter at 4500 and shift at what? 4500.
Thanks, but I will stick to the restrictor, it makes thing more consistant, and it has held my stock bottom together for a long time.
Old Feb 11, 2009 | 08:39 PM
Max01GreenMachine's Avatar
Max01GreenMachine
2017 C6 of the Year Finalist
Cruise-In VI Veteran
Indeed....
Old Feb 11, 2009 | 08:44 PM
LV Vette's Avatar
LV Vette
St. Jude Donor '08
I have a PSC-1 (the base one). I wonder if my boost gauge could be off. Maybe I can borrow one from someone, hook it up and see.
Old Feb 12, 2009 | 08:21 AM
Hvymtlc5's Avatar
Hvymtlc5
I'd be careful with those boost levels (11psi) in a stock LS1....rings in the rear cylinder will begin to self destruct because of the added heat. I just destroyed # 7 cyl. (of course) with 7 psi. Motor was stock with 65K miles and not run "that" hard that much....
Old Feb 12, 2009 | 08:32 AM
clemsondave
I could be wrong, but I believe it is difficult to get over 10# with a P1 and a 6 rib belt. Mine slips a little bit and just over 9#. To get 11# on mine, I'd probably have to go to a 3.5" or smaller and then it would really slip.
To Restrictor plates…are they
