clocking instructions
Old Feb 14, 2009 | 08:51 AM
Blow Torch's Avatar
Blow Torch
Default clocking instructions
Has anyone got the clocking instructions for a procharger P1SC1? Apparently, I need to move the snail portion of mine to work with the HO (stage I) intercooler system
Old Feb 14, 2009 | 08:58 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Here I found these:
Got it right here: The A&A Clocking Instructions
http://forums.corvetteforum.com/c5-f...-clocking.html
http://www.exoticperformanceplus.com...html?item=1227
Thanks,Matt
Old Feb 14, 2009 | 09:25 AM
Blow Torch's Avatar
Blow Torch
Thanks Matt
I found both of those while searching, but does that mean I have to pull the unit apart. One reply I received stated that the snail portion could be turned to a different position simply by loosening the allen screws on the outer casing.
If I need to pull the case apart, I may wind up sending it off (more delays)
Old Feb 14, 2009 | 10:33 AM
Brandon619's Avatar
Brandon619
Clocking the valute on the head unit is easy just undo the 10 alen bolts that hold it on the unit and move to new location. Now if you are going to reclock the oil slinging gear thats alittle more involved. You must pull the head apart and move the oil slinging gear to its new location. Both are fairly simple on a P1.
Old Feb 14, 2009 | 10:38 AM
Brandon619's Avatar
Brandon619
Here are some good instructions on clocking a prochager.
http://www.aacorvette.com/pdf/aa_pc_clocking.pdf
Old Feb 14, 2009 | 12:26 PM
Blow Torch's Avatar
Blow Torch
Brandon
I HOPE I only have to move the head unit. (It may not be called "clocking." My outlet is pointing at a 90* angle to the driver side and it needs to be pointing at an angle (toward the power steering pump) So I hope I only need to move the "snail"
Do you know what the torque on the bolts are?
Old Feb 14, 2009 | 04:54 PM
Brandon619's Avatar
Brandon619
No I don't know the torque but I just tightened them down good. Don't sweat it on moving the volute, easy job
Originally Posted by BOTTLE FED
Brandon
Old Feb 14, 2009 | 08:26 PM
madmatt9471
Thanks Matt
Sorry for the delay in my response, I see now what you have to do.
You need not worry you can turn the SNELL part of the unit by loosening the screws and turning the unit into the right position.
More than likely you are clocked right just make sure you check according the A&A instructions!
Keep us posted and continue with your patience - It will pay off
Thanks,Matt
To clocking instructions
