need help with methanol problem!
Old Feb 21, 2009 | 11:27 PM
a/c man's Avatar
a/c man
Default need help with methanol problem!
i went to the track today and my car quit! i noticed that meth was coming out of mt TB and the pump would not shut off! i found a vacuum switch and when i handled it the pump went off i think the switch is the problem! i never had any problems before my tuner reset my rev limit and shift points it must be pulling more vacuum I'm not sure can you help me with this problem or have you ever had this problem thanks Scott
Old Feb 21, 2009 | 11:29 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
If this is a weather sealed Hobbs switch, you need to replace it. If not, maybe it got wet. That will cause it.
Old Feb 21, 2009 | 11:34 PM
a/c man's Avatar
a/c man
how will i know if i have a hobbs?it is very small with 2 wires and a vacuum line 1''x1''x1/4 switch what do you replace it with? thanks
Old Feb 21, 2009 | 11:38 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Sounds like the HOBBS switch has malfunctioned!
The HOBBS switch works on BOOST pressure as opposed to vacuum. You can test the switch with a pressure tester, MIGHTY VAC, use a test light and see where it comes on at.
There is a small black plug in the bottom and you can turn it to have it come on sooner or later during B@@ST!
Thanks,Matt
Old Feb 21, 2009 | 11:39 PM
BLOWNBLUEZ06
It has to be a Hobbs switch. It's a pressure sensitive switch that closes when it reaches a certain pressure. Who made your kit? The Alky Control kit uses a MAP sensor and increases pump voltage with increasing boost, so you get more meth with more boost. A Hobbs switch is on/off. I use one for my secondary fuel system and Boost-A-Bump
Old Feb 21, 2009 | 11:40 PM
BLOWNBLUEZ06
Thanks,Matt
Some don't have the plug and are pre set from the factory to come on at a certain boost or vacuum.
Old Feb 21, 2009 | 11:41 PM
BLOWNBLUEZ06
To find a replacement, type Hobbs switch in Google. Get a normally open, adjustable, sealed one like Matt's talking about. The best place I can think to get one is from a turbo supplier.
Old Feb 21, 2009 | 11:42 PM
madmatt9471
Here is where you can learn a little about these HOBBS switches:
http://content.honeywell.com/sensing.../catswitch.asp
Thanks,Matt
Old Feb 21, 2009 | 11:51 PM
a/c man's Avatar
a/c man
my switch doesn't look like the Hobbs on that link that one on the link is like a oil sending unit mine is plastic! square! help maybe I'm messing with the boost a pump switch
Old Feb 21, 2009 | 11:54 PM
BLOWNBLUEZ06
Well, do you know who's kit is in the car?
Old Feb 21, 2009 | 11:57 PM
a/c man's Avatar
a/c man
my tuner installed it all i know its the new kind braided lines it can run 100% METH
Old Feb 22, 2009 | 12:01 AM
a/c man's Avatar
a/c man
My tuner installed it all i know its the new kind braided lines it can run 100% meth
what i mean is im stupid
Old Feb 22, 2009 | 12:16 AM
bgreen83's Avatar
bgreen83
Pics?
Old Feb 22, 2009 | 12:21 AM
a/c man's Avatar
a/c man
Thanks for your help(blown blue)(madmatt) ill get pics tomorrow you have shed light on the problem thans guys im stupid! When it comes to the meth inj
Old Feb 22, 2009 | 11:26 PM
felo357's Avatar
felo357
i had a problem before with meth pump not turning off and it was my battery. once i went below certain voltage the pump started pumping it was weird. it took me 1 week to find out my battery was the problem. so go get your battery check belive me it was that stupid.
Old Feb 23, 2009 | 12:02 AM
a/c man's Avatar
a/c man
will do but my motor lost #1 cylinder today at the track i think my meth pump quit! I'm sick thanks for your reply,Scott
Old Feb 23, 2009 | 02:29 AM
BLOWNBLUEZ06
Man, that really sucks! As for the Meth, before you run that car again, PM me and I'll give you my phone #. I can share some tuning and installation methods on the meth to prevent engine failure. If it quits for any reason, it will pull as much timing as you choose and do it quickly as well as add fuel to compensate for the loss of the meth.
To need help with methanol problem!
Old Feb 23, 2009 | 02:48 AM
a/c man's Avatar
a/c man
thats cool! do you tune! i need help!motors are not cheap!
Old Feb 23, 2009 | 10:03 AM
Z06wanted's Avatar
Z06wanted
BlownblueZ06 is a really knowledgeable guy and very helpfull.
Old Feb 23, 2009 | 10:28 AM
East Tx Muscle Cars's Avatar
0East Tx Muscle Cars
Former Vendor
Scott i called you back a few mins ago. Your kit is the AIS meth kit and that switch IS a pressure switch. it has a little ALLEN screw in it to adjust the METH. also, why would you think you popped the #1 CYL? most all the time is is the # 7 or 8 CYL on the stock motors with stock intakes. Did you check to make sure that the two wires that went to the switch were not touching each other and making contact and thats what was making you pump run? and if the pump went out you coudl have got DET. did you hear anything at the track that sounded like marbles rolling around?
