Ti Catback too small?
Old Feb 28, 2009 | 12:23 AM
HWY HNTR's Avatar
HWY HNTR
Default Ti Catback too small?
At what point is the Ti cat-back not free flowing enough? I currently have the APS kit with random techs welded on the mid pipe going into a Corsa Titanium cat-back.
Old Feb 28, 2009 | 12:36 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Well I don't have the CORSA TI's but I do have the C5 Z06 TI exhaust and I'm pushing 639 RWHP and 540 RWTQ through them and all is good!
Hope this helps some, but I would think you should be fine!
What are your numbers or are you shooting for a certain number with the exhaust?
Thanks,Matt
Old Mar 5, 2009 | 11:43 PM
HWY HNTR's Avatar
HWY HNTR
Do you think youll make more hp switching catback?
Old Mar 6, 2009 | 05:00 AM
Cliff99C5hardtop's Avatar
Cliff99C5hardtop
You will get about 10-15 more HP with a larger free flowing exhaust especially with turbos. There are also alot of guys on this forum running the Ti's with alot of HP too.
Old Mar 6, 2009 | 06:19 AM
madmatt9471
It's possible to get a few more out of it by switching! But I like the look and the Stealth sound of the TI Z06 exhaust.
If I were to go to another exhaust it would probably be a CORSA INDY - I've heard good things about them and the reason is I just do not like it loud inside the Vette at all and the Z06 TI's are great in that department.
I am doing the Flip Drive soon and I believe this is money well spent for me over an exhaust swap!
Remember there is also a Z06 muffler trick you can do to increase the flow and still remain with the same sound inside the cabin you just need someone to be able to weld Titanium
I can find the pics if you'd like just let me know
Thanks,Matt
Old Mar 7, 2009 | 02:55 AM
HWY HNTR's Avatar
HWY HNTR
I have the APS kit with HF cats on. Should I keep the Corsa Ti catback or switch back to the stock Ti's? I miss that higher pitched sound I have with headers and Ti's. The Corsa is more of a Borla-ish sound. What do you guys think?
Old Mar 7, 2009 | 08:26 AM
FunCool's Avatar
FunCool
I have the borla-stingers on my car and I miss the Ti's too. I'm going to put them back on also. The way I look at it is, I'll still beat the same guys that I beat and lose to the same guys that I lose too, but I'll be happy with a 10 second car and the Ti's. It's not like the car will run 9's anyway.
Old Mar 7, 2009 | 01:23 PM
HWY HNTR's Avatar
HWY HNTR
Looks like ill be putting on my Ti's and seeing how they sound. Even though I dont have the AR headers anymore, the turbo's should be pushing more air so I think Ill be getting a similar sound if not louder, right?
Old Mar 9, 2009 | 01:25 AM
C5Spirit's Avatar
C5Spirit
556RWHP going thru my Ti-s. They sound great at WOT and no drone inside.
Old Mar 9, 2009 | 02:35 AM
HWY HNTR's Avatar
HWY HNTR
Whats the setup?
Old Mar 9, 2009 | 09:27 AM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
The TI's will support a lot of hp, but you'll have to work harder to get it. If anyone followed APS's R&D for the C5 kits, they noted that on a STOCK ZO6, on the 8lb wastegate springs the car would initially hit 8lbs of boost, then start trailing off to about 7.5 lbs at the top of the powerband, indicating an exhaust restriction which was drilled down to being the stock TI's. Easily worked around, but food for thought.
Old Mar 9, 2009 | 10:27 AM
HWY HNTR's Avatar
HWY HNTR
Thats better then it spiking to 9-10psi during cold weather, isnt it?
Old Mar 9, 2009 | 11:09 AM
exploder's Avatar
exploder
I have 780whp through my Ti's. It probably is a restriction on my car, but I like the way they sound.
Old Mar 9, 2009 | 11:14 AM
HWY HNTR's Avatar
HWY HNTR
How do they sound at that power level? :drool:
Old Mar 9, 2009 | 11:26 AM
Fastbird's Avatar
Fastbird
Pro Mechanic
Depends on how you're looking at it.
Old Mar 9, 2009 | 02:30 PM
flash of red's Avatar
flash of red
I noticed a little slower spool up time between the bullets and the TI's till I did the bypass mod on the TI's. The TI's dont have the resonace and I like having the lighter weight exhaust. Do the bypass mod and you will really be happy with them.
Old Mar 10, 2009 | 03:20 AM
C5Spirit's Avatar
C5Spirit
Whats the setup?
LS1 A4
LS6 ported intake and TB, LG LT headers w/ hi-flo cats and "X" pipe.
Patriot heads 62cc, '04 ZO6 cam. 160* T-stat
A&A Vortech 10.2 boost and methanol spray.
3.42 gears.
Large tranny pan holding 3 extra qts of fluid and tranny cooler.
Old Mar 10, 2009 | 11:39 AM
Higgs Boson's Avatar
Higgs Boson
685/715 through the Ti's here. Like the light and quiet exhaust, def not woth 10-15 hp to deal with the loudness. I cut my mullet off long ago. (never had a mullet for the record).
To Ti Catback too small?
