SC air filter
Old Mar 4, 2009 | 07:09 AM
Blow Torch's Avatar
Blow Torch
Default SC air filter
I guess I'll be chasing down parts forever;
Since I built my own intake and charge system to replace the old HO system, I'm having to find (with your help) LOTS of parts.
I needed a good filter assembly, so I purchased Andy's SC filter. The problem is because of it's offset, it won't work with my application. It hits either way I turn it, so I need a similar filter with the inlet "centered. I found one online, but not absolutely sure it will fit.
This is the LAST PIECE of the puzzle that is keeping me from "test firing " the car. (of course after that there's tons more stuff) but I want to know if this thing will even run!!
Suggestions??
This is the K&N I found
599-RF-1040
Oval Tapered
Flange Dia - F: 4'', 102mm
Length - L: 7.5'', 191mm
Base Dim - MA: 9'', 229mm
Base Dim - SA: 5.75'', 146mm
Top Dim - MA: 7'', 178mm
Top Dim - SA: 4.5'', 114mm
Top Style: Metal
Flange Length - FL: 1.5'', 38mm
Old Mar 4, 2009 | 09:30 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
We have the filter with the inlet in the center, its basically the same as Andy's without being offset if that works for you. We can send one out today for you. 609-752-0321
good luck on your build
Old Mar 4, 2009 | 10:10 AM
Blow Torch's Avatar
Blow Torch
Can you PM me the price including what it would take to get it here by Saturday.
Thanks again
Old Mar 4, 2009 | 11:13 AM
bullitt4110's Avatar
bullitt4110
You can start the car with out the filter, it wont change anything if your just starting it.
Old Mar 4, 2009 | 01:04 PM
Drewstein's Avatar
Drewstein
We've done dyno pulls without filters without issue. I just wouldn't drive for long without one.
Old Mar 4, 2009 | 01:22 PM
Blow Torch's Avatar
Blow Torch
I know it wouldn't hurt it in a pinch, but although I've blown everything off very well, I'm just know that I did a LOT of cutting and grinding during the install, and I wouldn't want to "suck up" any particles through the SC.
If I can't get something by this weekend, I'll definitely fire it up, but I'd really like to drive it if it's a clear day, but I won't without a filter.
Old Mar 4, 2009 | 02:34 PM
Steve@AandACorvette's Avatar
0Steve@AandACorvette
Former Vendor
From: Oxnard SoCal www.aacorvette.com www.superchargersuperstore.com
you've got mail
To SC air filter
