Fuel Pumps?
Old Mar 4, 2009 | 08:44 AM
Red38302's Avatar
Red38302
Cruising
Default Fuel Pumps?
Looking for some help....
I have a 383, PSC1, 60 lbs injectors, BAP and a Racetronics pump. I am making 604 RWHP and fuel pressure is dropping at 6-8 lbs of boost. It is my second Racetronics pump. Any sugesstions?
Old Mar 4, 2009 | 12:08 PM
Z06wanted's Avatar
Z06wanted
Give Will @ RSI and buy a twin intake setup from him.
Old Mar 4, 2009 | 12:29 PM
user_name's Avatar
user_name
Are you using a racetronix harness?
Old Mar 4, 2009 | 01:03 PM
breecher_7's Avatar
breecher_7
This is the way we went as well, great fuel hat. But I wouldnt use the pumps supplied. You can go much bigger and they are the same size and will work with the hat. We are using th Ford GT pumps that are made by walbro and rated at 430Lph each. You can get them for about $100 a piece.
Old Mar 5, 2009 | 07:45 PM
Red38302's Avatar
Red38302
Cruising
The pump is hooked to a MSD.
Who is RSI?
Old Mar 5, 2009 | 07:49 PM
breecher_7's Avatar
breecher_7
racingsolutions.com
And no, the pumps are hooked up however you want them hooked up. Preferably with a relay activated power lead from the alternator.
Old Mar 5, 2009 | 08:51 PM
Red38302's Avatar
Red38302
Cruising
Thanks.
I did not put the pump in.
It does have the BAP.
After 6-8 months the Pressure is now dropping on hard pulls.
I have heard different stories on how much RWHP the Racetronics can produce (from 600-700Rwhp). Mine was at 604 RWHP and it seems like the pump can not make enough pressure now.
Pump gone bad or at the limit for the pump? Maybe both?
Old Mar 5, 2009 | 09:30 PM
breecher_7's Avatar
breecher_7
Thanks.
BAP's leave to much variable for fluctuating fuel pressure in my oppinion. I hate them. Put two big pumps in the tank and forget about it.
Old Mar 6, 2009 | 07:45 AM
Racetronix's Avatar
Racetronix
Supporting Vendor
If you do not have a return system this is normal. From our web ad:
Technical note:
The Racetronix fuel pump in this system is capable of supporting apx. 600RWHP @ 0.5 BSFC @ 58PSI (400KPa) using factory lines. In early model C5's with rail-mounted fuel pressure regulators the above HP support can be achieved. Addition of a pump voltage booster may increase support to apx. 700RWHP. Cars with superchargers, turbos and low battery voltage may see lower HP support numbers.
Late model C5's with the returnless rail system will not be able to achieve this level of HP support with the fuel system alone.
This is because the point of regulation is at the back of the car. The location of the FPR does not allow it compensate for line
pressure drop even though the pressure is stable at the back (regulator location). There are two options to get around this problem.
First is to convert the system to a rail mounted FRP return type (best). The second option is to install a pump booster which is
activated at the point where rail pressure starts to drop. The boost in fuel volume overwhelms the regulator / return line thereby
increasing the fuel pressure at the back of the car which translates to higher pressure at the rail. We recommend the MSD unit for
FI applications as it ramps the voltage based on manifold pressure. This prevents a short but abrupt fuel pressure spike which
causes the motor to hiccup from brief over-fueling. If you are using an instant-on N2O system then the KB BAP can be considered as well.
Please understand that this is not an issue with the Racetronix system but rather a design limitation of the factory configuration.
If you do have or install a FMFPR system you may still be on the edge running that HP with a FI setup.
A simple plug and play solution would be a Racetronix / Lonnie's dual in-tank system for apx. $600-$700. A DP system can support upwards of 1000RWHP!
Old Mar 6, 2009 | 11:52 AM
clif's Avatar
clif
St. Jude Donor '09-'10
I just had to tame an MSD BAP off my 99. After trying to figure out fluctuating fuel pressures for a couple of months (since I installed the BAP), I talked with MSD support. They told me the MSD WILL NOT WORK on a returnless system, like my 99!
Technical note:
Old Mar 6, 2009 | 12:01 PM
Racetronix's Avatar
Racetronix
Supporting Vendor
LPE uses boosters all the time as well as many of our other dealers. Perhaps MSD does not know how to solve your specific problem hence their response?
Old Mar 6, 2009 | 12:02 PM
Racetronix's Avatar
Racetronix
Supporting Vendor
A good FM regulator with a return line is really the fix.
To Fuel Pumps?
