I'm about to install an ECS fuel system on my 04Z and was wondering if anyone has a drawing of the layout? Overall, I have a general idea of where everything goes, but I'm little confused about the connections up front by the rails. Any help or suggestions would be greatly appreciated!
although I dont have a layout, I do remember reading a thread recently, and it had some pretty great layout pictures. It was somewhere in the C5 section.
I'd do a search for ECS Fuel System, and you will find it... Just make sure you make it look in "Titles Only". Dont do a search wich "Search all posts". Cause if you do, he thread will get buried based on the amount of times ECS is mentioned.
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Feel free to call the shop if you still have questions, there are so many different ways it can be laid out depending on your set up that it is difficult to make a set instruction package. Mike04's install was very clean if I recall and should fit with your set up as well.
Was on the phone with Doug today and got everything sorted out, thanks! I did however run into another problem and possibly a dangerous one. One of the connectors that attaches to the stock hard tube fuel line comes off very easily. Its suppose to click in place which it does, but you can easily pull it off with your hand. I wouldn't want it coming off and spraying fuel on a hot engine This is the fitting I'm referring to:
I tried another new identical fitting and it did the same thing. However, when tried on a older fuel rail it wouldn't come off without prying it. Has anyone had this happen to them? Is there any other connector I could use or can someone suggest any ideas?
