JP double roller install
Old Mar 17, 2009 | 05:03 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Default JP double roller install
Im wanting to install my cam "dot to dot" but the JP double roller timing set doesnt have "dots" like the stock gears. It does, however, have numbers on the outter teeth and the inner plate of the crank gears. Im assuming that I set the bottom gears with the 0 on the tooth strait up but im curious about the larger cam gear? I dont see markings of any kind and Im wondering what to do.....
BTW, this is going in for my TT build so let it stay in the FI section LOL
EDIT: I was BLIND !! I found the dot on the cam gear. But I still need to know which "0" on the crank gear do I line up the cam gear with? The one closest to the center of the gear or the outermost 0 that is on the tooth?
Old Mar 17, 2009 | 05:04 PM
exploder's Avatar
exploder
0 is dot to dot
Old Mar 17, 2009 | 05:09 PM
Corvette-Chris
St. Jude Donor '08
Originally Posted by exploder
0 is dot to dot
The crank gears have numbers and (unless Im blind) the cam gear does not....that is my question.
To JP double roller install
