Fuel Pump Operation
Mar 17, 2009 | 07:54 PM
Fuel Pump Operation
Question, im stumped....
Fuel pumps come on, No Fuel pumping.
Reversed Polarity, No fuel Pumping....
THey are running in both scenarios, but no fuel comes out....
Pumps worked fine when removed in fall...
Ideas?
Mar 17, 2009 | 08:04 PM
I wonder if something is stuck shut up stream like the check valve or the regulator. If you open up the line towards the rear, maybe around the filter and then turn them on for just a second do they work?
Mar 17, 2009 | 08:11 PM
Nope, i have both -6 feed lines open right at the tank.... Tanks are full... NO fuel.
This is why im stumped...
Mar 17, 2009 | 09:29 PM
Nevermind, im brain dead....
Pumps were air bound badly for some reason and the 2 sec prime that the car does when you turn the ignition was not enough to get them loaded.
When I commanded them on with HP tuners they primed....
Mar 18, 2009 | 12:17 AM
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Quote:
Originally Posted by
breecher_7
Wheeew! That was close because I was just ready to recommend a bucket test
I thought perhaps the fitting inside the tank had come loose and it was just pumping inside the tank and able to deliver in the fuelk line!
Welcome good old AIR-LOCK
Thanks,Matt
Mar 18, 2009 | 01:12 PM
Glad you figered it out and it was cheap for a change.
Mar 18, 2009 | 02:22 PM
St. Jude Donor '06 & '12
Its always the simplest things that stump you.. We are soo used to looking for the needle in the haystack, that we never look for the obvious..HAHA.
breecher_7
Mar 18, 2009 | 02:26 PM
Jeff @ TPE
SO true.....
Where's my meth plate!
Mar 18, 2009 | 09:55 PM
Jeff @ TPE
Tech lesson 101 the "KISS" method has been around for years.
“Keep It Simple Stupid”.
Always look for the simple things first, and it looks like he did just that. In less than 1 ½ hours he had it figured out.
Does that still work in todays world?
