How much does the 8rib conversion run?$?$?
Old Mar 31, 2009 | 06:50 PM
Kamil's Avatar
Kamil
Default How much does the 8rib conversion run?$?$?
Hey guys just a quick question how much does the 8rib conversion run?$?$?$?$? Im running a D1SC
KAMIL
Old Mar 31, 2009 | 07:16 PM
Steve@AandACorvette's Avatar
0Steve@AandACorvette
Former Vendor
From: Oxnard SoCal www.aacorvette.com www.superchargersuperstore.com
$995
Old Mar 31, 2009 | 09:41 PM
user_name's Avatar
user_name
If you are doing the install yourself you might factor in $150 for a laser alignment tool. You will also need to rent/but the pulley puller and install tools.
I rented the ps pulley tool, had the crank pulley tool, and got lucky on alignment (I guess) after about 10 tries...lol.
Old Apr 1, 2009 | 11:39 AM
LJo's Avatar
0LJo
Former Vendor
Is it a Stg 2 Procharger system?
If so we charge $400 without balancer
p/n 3GKPB-003
This is all the bracket spacers, pulleys and hardware. All you will have to do is order an 8-rib aftermarket balancer.
Old Apr 1, 2009 | 12:22 PM
Kamil's Avatar
Kamil
p/n 3GKPB-003
Do you know how much the balancer costs?
Old Apr 1, 2009 | 12:56 PM
LJo's Avatar
0LJo
Former Vendor
Innovators West
http://www.innovatorswest.com/store/...wCat&Submit=Go
ATI Performance Products
http://www.atiracing.com/products/da...ts/damserp.htm
I am not a dealer for these products so I don't have pricing on them.
Old Apr 1, 2009 | 01:30 PM
mdhmi's Avatar
mdhmi
$1,500 - $2,000 if you factor in labor and a retune.
Old Apr 1, 2009 | 01:51 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
You should also keep in mind that you'll need to factor in the fact that the balancer is an overdrive balancer when ordering the pulley for the Procharger.
Old Apr 1, 2009 | 02:35 PM
LJo's Avatar
0LJo
Former Vendor
Originally Posted by blownbluez06
you should also keep in mind that you'll need to factor in the fact that the balancer is an overdrive balancer when ordering the pulley for the procharger.
edit
To How much does the 8rib conversion run?$?$?
