Maggie Question
Old Mar 31, 2009 | 10:13 PM
The Yav's Avatar
The Yav
Default Maggie Question
Gentleman,
How much PSI is does the stock Maggie pulley produce? I will be running 11 to 1 comp, LT and a 228/588/114 camm with a conservative tune.
Will I have to get a 4 PSI pulley due to comp? I was told a rule of thumb figure 20 hp for every pound of boost. My car is currently 433rwhp/401 fptq
v/r
THEYAV
Old Apr 1, 2009 | 08:16 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
If you tune it properly, you should be able to run up to 10psi without issue. If you want a more conservative approach, try running 7psi.
Old Apr 1, 2009 | 09:09 AM
Vega$Vette's Avatar
Vega$Vette
Originally Posted by The Yav
Gentleman,
v/r
THEYAV
Stock pulley is about 7 psi.
I'm running a stock pulley with 10.9 - 1 compression. With Stage II heads and long tubes. Cam is 224 575 114. Boost shows 5.6 psi. This is due to a better flowing heads etc.
I'm at 502 rwhp and 469 torque on a conservative tune. (was 407 rwhp NA)
Maggies work very well with higher compression. Nice that you have good power when not boosting and when you do hit it the power is instant.
Old Apr 1, 2009 | 03:45 PM
The Yav's Avatar
The Yav
Vegas vette,
Thanks for the info what kind of hood do you have, I am considering a Caravaggio hood
Old Apr 1, 2009 | 03:50 PM
Vega$Vette's Avatar
Vega$Vette
Vegas vette,
Caravaggio Blower Hood
Old Apr 1, 2009 | 04:57 PM
itchynackers's Avatar
itchynackers
If 14.7psia is ambient pressure, then you will get 1/14.7 % for each psi gain.
So for rwhp, 1/14.7 * (345rwhp) = 23 rwhp minus additional heating losses
This is assuming you had 345 rwhp NA.
Old Apr 1, 2009 | 10:55 PM
The Yav's Avatar
The Yav
Vegas Vette,
Can you post or send me some pictures of your hood. Thanks for all the information, I was told by my tuner the setup would work but it's always good to hear from the source.
v/r
THEYAV
Old Apr 1, 2009 | 11:37 PM
Vega$Vette's Avatar
Vega$Vette
Vegas Vette,
v/r
THEYAV
Hood's in my sig post #3
To Maggie Question
