gauge install help
Old Apr 3, 2009 | 09:06 PM
1320IN9's Avatar
1320IN9
Default gauge install help
i will be installing dynotune gauges next week,boost and fuel press, i have done f-bodys in the past but not a vette, they will be mounted in the ashtray."beer panel" where in the car is a good power source to tap into and where to run wires out to the engine? any tips or even pics will be great to give me a head start.. thanks
Old Apr 4, 2009 | 06:06 AM
Beer99C5@FastbirdPerf.com's Avatar
St. Jude Donor '08
Depending on the year of the car, there should be a Factory Pigtail in the passenger footwell. There are three wires a yellow, orange and black. One is hot all the time, the other is switched, and the black is the ground. If you have this its in the upper left side of the footwell, usually wrapped in black duct tape.
Jim
Old Apr 4, 2009 | 05:17 PM
1320IN9's Avatar
1320IN9
car is an 03. ill check the footwell for that pigtail.
Old Apr 4, 2009 | 05:35 PM
tail_lights's Avatar
tail_lights
Jim
Old Apr 4, 2009 | 07:57 PM
slothy's Avatar
slothy
u doing a mechanical boost or electronic (map sensor) - the elec one requires a non interrupted power source to calibrate - which had to pull off from a wire near ignition.
Old Apr 4, 2009 | 10:24 PM
1320IN9's Avatar
1320IN9
i am using the square dynotune electronic gauges
Old Apr 7, 2009 | 01:39 PM
Steve@AandACorvette's Avatar
0Steve@AandACorvette
Former Vendor
From: Oxnard SoCal www.aacorvette.com www.superchargersuperstore.com
A-pillar mount, but you can do the same wiring as this:
http://www.aacorvette.com/pdf/aa_c5_...structions.pdf
Old Apr 7, 2009 | 06:05 PM
1320IN9's Avatar
1320IN9
cool thanks..very helpful
To gauge install help
