stock tensioner
Old Apr 8, 2009 | 01:56 PM
optimum01's Avatar
optimum01
Default stock tensioner
408 motor with d procharger-old setup(dual intercoolers and old bracket)Tensioner chirps after a while-tried using a c6 tensioner and same type of noise.Is this noise problematic or just annoying?I dont want to change to whole belt setup-its 8rib and aligned nicely.Someone said try SDCE-anyone have advice?Thanks
Old Apr 8, 2009 | 02:30 PM
optimum01's Avatar
optimum01
anyone?
Old Apr 8, 2009 | 09:49 PM
Arun@ChampionMotors's Avatar
0Arun@ChampionMotors
Former Vendor
The SDCE setup is for F-bods. I would try a Gatorback or Dayco Polycog belt first-cheapest solution.
Old Apr 9, 2009 | 01:20 PM
optimum01's Avatar
optimum01
Guess I'll try it-I imagine as any other new belt it will stretch and have to be retightened.Funny how some years ago the concensus was gates green stripe as the way to go which is what I am using.
Old Apr 9, 2009 | 01:52 PM
Former Vendor
In every application where the belt slipped, I replaced it with a Goodyear or Dayco Polycog and no more issues.
Old Apr 10, 2009 | 12:52 PM
optimum01's Avatar
optimum01
I am noticing now the noise comes on after about 3miles of driving-seems to be comming from the head unit area.Changed unit oil recently-hope its not that c6 tensioner someone recommended.Nothing wobbling-belt looking straight with no wear-just that chirping pulley type noise.
Old Apr 13, 2009 | 01:04 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Hey! Did you ever find the culprit?
I had the AC tensioner and idler squeeking and I thought it was the P1's tensioner but I was wrong and all was good after i changed the suspected tensioner
Thanks,matt
Old Apr 13, 2009 | 01:11 PM
leo12's Avatar
leo12
boy everytime i used a gatorcrap i snaped it
went with GATES-V never had a problem
Old Apr 13, 2009 | 04:19 PM
Former Vendor
Probably because the belts harder-which means it's not soft, so they slip. But hey we make 900 rwhp on the Gatorbacks on regular basis.
Old Apr 15, 2009 | 03:54 PM
optimum01's Avatar
optimum01
Havenot found the culprit yet - cars at the shop.
To stock tensioner
