Fuel Pump issues?
Old Apr 12, 2009 | 12:32 AM
Toby Van Horn's Avatar
Toby Van Horn
Default Fuel Pump issues?
I have a 99 maggie with an upgraded fuel system (do not know excactly which one) and for the past 9 months I have owned it has always been 60psi. I recently had to do valve springs and got it running today, took it for a drive and forgot to hookup the fuel pressure gauge. When I got to the gas station I hooked up the wire for the guage. When I went to leave it would not start (no pressure). I got it towed home. When I got it home the tow truck driver needed the mileage so I put the key in and it went right to 55 psi and started and ran.
In the boost a pump setup is there a second pump? a larger pump in the tank? Amplified power to a stock pump?
What should I do to test different parts of my system, or find out what system I have?
Toby
Old Apr 12, 2009 | 12:55 AM
Toby Van Horn
also for a s/c 500 rwhp what psi should it be running?
Old Apr 12, 2009 | 01:00 AM
Toby Van Horn
the only rec I have for the fuel system states CARTEK installed a fuel system (looks like supplied by customer) and put 42lb injectors on it. in 5/04.
Old Apr 12, 2009 | 09:46 AM
sultan 2 ZR1 KSA's Avatar
sultan 2 ZR1 KSA
I think you should test your ground wires
Old Apr 12, 2009 | 08:55 PM
Toby Van Horn
sounds good, talked to the prev owner and found out he is running a racetronics pump with an MSD boost a pump.
Old Apr 12, 2009 | 08:56 PM
Toby Van Horn
what PSI should you see from a setup like mine (maggie / 500rwhp)
Old Apr 12, 2009 | 09:12 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
55-60 will be fine. Not sure you even need a BAP. The old MSD voltage boosters were less than reliable. I wouldn't be surprised if it was going out.
Old Apr 12, 2009 | 09:53 PM
Toby Van Horn
not being familiar with those setups, where are they typically mounted?
Also when they go out do they stop working at boost, or does it interfere with normal oporation?
Old Apr 13, 2009 | 12:25 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Thanks,Matt
Old Apr 14, 2009 | 10:12 PM
Toby Van Horn
checked / cleaned all connections, driven 6-10 times almost 100 miles and everything seems to be okay, i will keep you updated.
To Fuel Pump issues?
