Dyno results!!!!!!!!!!!!!!!!!
Old Apr 15, 2009 | 12:36 AM
SCRMNC5's Avatar
SCRMNC5
Default Dyno results!!!!!!!!!!!!!!!!!
Here it is guys. Dyno run after D1SC install, freshly ported heads, and a SD tune. other mods are:
SLP long tubes
SLP free flow cats
Corsa Pace car exhaust
Ported/polished TB
Ported intake manifold
60# fuel injectors
Kenne bell boost a pump
Spec twin disc clutch
Old Apr 15, 2009 | 12:48 AM
SCRMNC5's Avatar
SCRMNC5
Here's the video!
Old Apr 15, 2009 | 01:37 AM
TheDingo's Avatar
TheDingo
Nice numbers! Congrats!!
Old Apr 15, 2009 | 06:15 AM
9secondflat's Avatar
9secondflat
what does WCF stand for? also i kept waiting for that sign to fall.....
Old Apr 15, 2009 | 06:41 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Very nice!
If I am reading it right - you are running 9+ PSI of BOOST correct?
Enjoy and be safe
Thanks,Matt
Old Apr 15, 2009 | 11:10 AM
SCRMNC5's Avatar
SCRMNC5
Originally Posted by madmatt9471
Very nice!
Enjoy and be safe
Thanks,Matt
Yes, and thank you, I will. It's a whole different monster now!
Old Apr 15, 2009 | 12:17 PM
csexton's Avatar
csexton
Congrats
Old Apr 15, 2009 | 12:59 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
I take it you have a stock bottom and if so those are really nice and safe numbers
Old Apr 15, 2009 | 02:39 PM
SCRMNC5's Avatar
SCRMNC5
Yes stock bottom end still. We might trim it down just a hair, this run was done without the boost a pump installed. we we're running out of fuel at 5500rpm's.
Old Apr 15, 2009 | 06:05 PM
tail_lights's Avatar
tail_lights
Definately don't want to run out of fuel on a stock bottom end! (any bottom end for that matter....)
Nice numbers!
Old Apr 15, 2009 | 08:09 PM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
Very good.
Old Apr 16, 2009 | 08:14 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
What kind of valve springs do you have? It looks like you either need better valve springs or your burst knock table raised up.
Old Apr 16, 2009 | 10:17 AM
SCRMNC5's Avatar
SCRMNC5
stock springs, any suggestions would be appreciated.
Old Apr 16, 2009 | 09:15 PM
TheCartel's Avatar
TheCartel
No aftermarket cam then? If so, at least some comp 918s. You can still use your stock seats and retainers.
Old Apr 17, 2009 | 03:38 PM
SCRMNC5's Avatar
SCRMNC5
nope, stock cam as well. i am planning on going bigger over next winter, maybe 402 or even 427, not sure yet, should i wat till then to do the valve springs?
Old Apr 17, 2009 | 03:45 PM
Warp Factor's Avatar
Warp Factor
You have a sag in the dyno curve which might be valve float.
Old Apr 17, 2009 | 05:46 PM
road pilot's Avatar
road pilot
Are you happy? Yea, for how long?
Old Apr 17, 2009 | 07:46 PM
TheCartel's Avatar
TheCartel
I would do it now just in case for safety sake. Thats just me, im not rich so I need **** to last. lol.
To Dyno results!!!!!!!!!!!!!!!!!
