Ok, so some of you may now I bought a meth kit from the for sale section and well it was JUNK!!!
Hooked it up today and the freaken progressive control doesn't work. So I was goin to wire it up to turn on when it see's boost using my KB boost-a-pump switch.
I am only running 6-7# and was wondering if it is worth buying the new progressive control or just hooking up to the boost switch.
Would be better, but can control the amount also, but at that low of boost should be ok, just check you meth container, dont run out.
