boost pump wire help
Old Apr 26, 2009 | 11:54 AM
1320IN9's Avatar
1320IN9
Default boost pump wire help
i am in the middle of the KB boost pump install, just mounted the box, ran the racetronix harness up to the alternator, pluged everthing in but im stuck. on the racetronix harness i have the quick bap connections that i bought with the harness, on the BAP the wire with the fuse on it where does it get pluged into on the harness, there is a thin red wire and a thick red wire. so the wire with the fuse goes to which one?? they are not labeled and i dont want to plug the wrong one in.. thanks
Old Apr 26, 2009 | 01:57 PM
Blow Torch's Avatar
Blow Torch
The wire with the fuse hooks to the racetronic wire that goes to the altermator. The other red wire on the racetronic harness hooks to the other end (after you unhook them)It hooks into the interface shown here
http://www.racetronix.com/product/RX...WH-2/C5102.jpg
Old Apr 26, 2009 | 04:35 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Here's my write up with pics to help you out!
http://forums.corvetteforum.com/c5-g...ll-w-pics.html
Although I have a MAGNAVOLT it is essentially the same
Thanks,Matt
Old Apr 26, 2009 | 05:14 PM
1320IN9's Avatar
1320IN9
thanks guys, i figured it out. i had the wires crossed, i had the wire with the fuse going to the thin red wire on the harness so i switched them over, good thing racetronix gives you extra connectors in case you mess up, now before i put the wheel well back in how can i confirm the BAP will come on with boost? can i jump it with a wire and listen to see if it turns on? thanks
To boost pump wire help
